Author Topic: K Jet DX Engine not starting  (Read 9673 times)
Re: K Jet DX Engine not starting
« Reply #30 on: 14 February 2011, 09:20 »
The difference in the rotor arms is that the larger one is a rev cutting version, smaller one should be fine but if your looking for a rev limit then fit the bigger one.
« Reply #31 on: 14 February 2011, 11:34 »
as above, on the smaller rotor arm cars the rev limiter is built into the fuel pump relay
Offline bmouthboyo
« Reply #32 on: 18 February 2011, 22:26 »
any advice regarding the 8mm tank outlet to the larger 12mm pump inlet? and the co2 adjustment?
Thanks
