Author Topic: astra gte digi dash??  (Read 33395 times)
Offline davies1644
« on: 23 January 2011, 20:53 »
right just wondering as an astra gte digital dash will fit into a mk2 golf will it fit into a mk3 golf? only problem i can really see is the fact that the gte clocks use a transponder but will this just plug into the box? got an 02 box i think on a tdi??
Re: astra gte digi dash??
« Reply #1 on: 23 January 2011, 21:18 »
I think the problem will be the rev counter, not sure how you get that to work.
Offline davies1644
« Reply #2 on: 23 January 2011, 21:45 »
why will that be a problem? can just use the original signal wire that the clocks use now
« Reply #3 on: 23 January 2011, 21:49 »
Not that easy, Astra GTE use a pulsed feed from the alternator, the signal wire you have now will not work.
Not 100% sure how you would get around it.
Offline davies1644
« Reply #4 on: 23 January 2011, 22:43 »
i was under the impression that the gte dash used pulsed anyway like all digi dashes? also is the mk3 not the same as a mk2? as they work fine in them
Offline stainesy
« Reply #5 on: 24 January 2011, 06:41 »
very interested to see how this thread turns out. i may do this mod if you can get it to work.
i put the digi dash in my mk1 astra gte and loved it.
didnt no you could put them in golfs  :shocked:
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #6 on: 24 January 2011, 07:07 »
I have converted loads of these.
Will check into the MK3 for you a bit later mate.......Sure we can can do it.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #7 on: 24 January 2011, 07:25 »
You may find this of interest in the meantime time mate.  Dom knows everything about digi-dash's.
He has his own little forum, here is the link........
http://www.picbits.co.uk/forums/
And his shop......
http://www.picbits.co.uk/catalog/
« Reply #8 on: 24 January 2011, 08:39 »
mk2 uses a speedo cable from memory, are you sure it is the Astra dash fitted and not something else.
« Reply #9 on: 24 January 2011, 09:33 »
MK2 digifiz uses a speedo sensor in the gearbox :)
if the astra dashneeds a pulsed -ve signal the same as what the standard MK2 golf uses then open the coil and put a wire to the -ve terminal. if it needs an alternator signal simply run a wire to the 2nd unused pin on the alternator plug.  if it uses the same signal as the mk2 digifiz dash, then the oem mk3 rev signal wire is compatible
