Author Topic: Knock knock knocking!! Help!!  (Read 899 times)
Offline Marc3GTI
« on: 23 January 2011, 19:20 »
P reg Gti anni,
2 visits to a local garage having clutch, cable and seals sorted due to slipping clutch....expensive.
After 2-3 days of having it back, I recently selected 5th gear and a knocking noise began, i moved down the gears then back up to 5th and the noise began again?
Gear box knacked? Hope not, any ideas and remedies would be great cheers
Re: Knock knock knocking!! Help!!
« Reply #1 on: 23 January 2011, 19:25 »
Could be a cv joint or the gearbox.
Offline Marc3GTI
« Reply #2 on: 23 January 2011, 19:28 »
CV joint?
Im a dunce when it come to this stuff?
« Reply #3 on: 24 January 2011, 09:27 »
check the gearbox oil, if its low 5th starts to run dry
Offline golf_mk3VR6
« Reply #4 on: 24 January 2011, 16:10 »
Chech the GB back mount.
Get under it and start pulling from the axels, and see If you get any noises.
MK3 AAM wagon, dreaming of a VR6
