Author Topic: Dash LED's  (Read 2542 times)
Offline Jimmy Filth
Dash LED's
« on: 23 January 2011, 18:07 »
I know this has been discussed a million times, but I can't find the answer to my particular question...
So, I've bought a load of 3mm LEDs to go into the switches on the dash/door and roof switches.  I've taken the switches apart and installed the LED's, but when I put them in the car they blew.  They're 12v LEDs and was told that I wouldn't need resistors in them.
I take it I was misinformed and I in fact I do need resistors, but how the hell do I git a resistor in?  Tjhe switches are very tight and I can't see how I would go about it......
7R 5 door.  Limestone Grey.  19" Pretoria's, Leather, DCC, Winter pack, keyless entry, rear camera.
Offline sharki786
  • GOT BOOST??
Re: Dash LED's
« Reply #1 on: 24 January 2011, 10:22 »
i had same prob with some red & blue leds, the blue leds needed resistors but the red didnt then i got some super bright red leds and they needed the resistors.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Jimmy Filth
Re: Dash LED's
« Reply #2 on: 24 January 2011, 10:27 »
hmmmm.  I may need to buy resistors then, they worked for about 0.01 of a second.  I'm not really sure how i'm going to fit resistors in there thoug...
Offline sharki786
  • GOT BOOST??
Re: Dash LED's
« Reply #3 on: 24 January 2011, 17:48 »
ok, on a led you got 2 legs the longer leg is + short leg is - the resistor will only go 1 way. hope that helps.
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=7078889 i think this was the resistor that i used and the gold stripe was used on the led + side and yellow strip side was used to the wire.
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=retrieveTfg&binCount=7325&Nty=1&Ntx=mode%2bmatchallpartial&Ntk=I18NAll&Ne=4294957561&Nr=AND%28avl%3auk%2csearchDiscon_uk%3aN%29&N=4294611873&Ntt=resistor these are all of the resistors ring them up and they should be able to help you alot more.
*****MK4 GTI T*****
Offline Walkerboy
Re: Dash LED's
« Reply #4 on: 30 January 2011, 19:18 »
kells is the best for things like this if your still having probs dude
Offline Jimmy Filth
Re: Dash LED's
« Reply #5 on: 30 January 2011, 20:04 »
I've overcome most of the problems through bliss and ignorance. The only issue I'm having at the minute is how damn fiddle certain bloody switches are. Haha
Offline Len
Re: Dash LED's
« Reply #6 on: 31 January 2011, 12:58 »
F17BAD now! :wink:
www.sas.org.uk
www.the-ace.org.uk
