Author Topic: Disconnected connector  (Read 3891 times)
Offline richandhazel
« on: 21 January 2011, 17:01 »
Anyone know if this is meant to be connected to anything. :huh: :-
Just spotted it hanging down and nowhere obvious to connect it to :undecided:
Christo77
Re: Disconnected connector
« Reply #1 on: 21 January 2011, 17:19 »
It looks like one of those connector types that fit onto a water temp or maf sensor terminal..bit of a guess though from here, someone will know for sure.
Offline LowlifeDubber
« Reply #2 on: 21 January 2011, 18:05 »
Looks like the plug that plugs onto the hall sensor on the side of the dizzy.But i see you have a coilpack.So fluck knows :grin:
« Reply #3 on: 24 January 2011, 08:57 »
could be the electric coolant plug from the wire colours, but i dont know where it is on a vr6?
« Reply #4 on: 24 January 2011, 14:37 »
One of the coolant sensors?
They are at the front here and appear to be accounted for:-
This one shows the connector and the coolant sensors:-
The hall sensor for the dizzy sounds good as it is probably the same loom as a standard Mk3 but it does seem a bit gash and unvolkswagen like to simply leave it dangling :huh:
Offline Len
« Reply #5 on: 24 January 2011, 14:56 »
A case of find the nearest receptical and see if it does anything! :wink:
www.sas.org.uk
www.the-ace.org.uk
« Reply #6 on: 24 January 2011, 14:57 »
Could be the plug for the auxiliary / electric water pump as RJ said.
« Reply #7 on: 24 January 2011, 14:58 »
That's the problem, there isn't anything that I can see. I'm wondering if there is something buried under the shroud that I can't see :undecided:
Offline Len
« Reply #8 on: 24 January 2011, 15:00 »
Looks like it dont go very far so yes maybe there is something under there!
www.sas.org.uk
www.the-ace.org.uk
« Reply #9 on: 24 January 2011, 15:00 »
Ah.....the auxiliary water pump. I wonder if that has been removed :undecided:
I'll have to take a look in the manual and find out where it should be fitted.
