Author Topic: Waiting in McDonalds for the dreaded phone call ...  (Read 3864 times)
Offline walchy01
« on: 20 January 2011, 16:39 »
Car in for Mot test, awaiting the phone call to fetch it and the long list of failures to come with it :cry:
Like waiting for my bloody exam results years and years ago :rolleyes:
Look out me later asking questions about everything it has failed on...
Offline Adam
Re: Waiting in McDonalds for the dreaded phone call ...
« Reply #1 on: 20 January 2011, 17:43 »
All the best. Let us know how it gets on.
Down Hill From Here.
Offline walchy01
« Reply #2 on: 20 January 2011, 18:07 »
1. Rear fog  light not working
2.steering column top mount bracket insecure.
3.exhaust not adequately supported
4. Nearside rear brake binding.
5.offside front brakehose has insufficient room to move, resulting in fouling on any part.
6.offside front brake hose twisted.
7.offside front subframe mounting prescribed area is excessively corroded, size of a jack head approx....
That's is. How much guys???
Offline Adam
« Reply #3 on: 20 January 2011, 18:20 »
Bulb maybe wiring switch
New bracket or new bolt?
New rubbers
HB cable, calliper or just needs a good wire brushing
Remove calliper and untwist the hose will rectifie ^ make sure the hose isn't past it from the fouling
Bit of welding
Not too much work to be honest. You could possibly do it all yourself minus the welding.
« Last Edit: 20 January 2011, 19:36 by Adam »
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #4 on: 20 January 2011, 19:55 »
Not bad could have been much worse !
Offline xkaty_h
« Reply #5 on: 20 January 2011, 20:15 »
As mentioned, not a bad MOT result at all!
Offline emery1990
« Reply #6 on: 20 January 2011, 20:38 »
Look around for the rear fog light fault. My mot man said my rear lights wernt working, bought a new switch at a tenner went to fit and noticed the spade bit had fell off  :angry: worked after that!
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #7 on: 20 January 2011, 21:32 »
Look on the bright side.
Fewer things to fail on next time.
Chin up!
Jonathan.
Offline dan_apps
  • too low for british roads!
« Reply #8 on: 20 January 2011, 22:28 »
mostly free if you get underneath and asked the MOT chap to tell you where and what exactly needed doing. if thats all the rust you have you are very lucky, get a tidy welder to do it and its a sound job!
Offline walchy01
« Reply #9 on: 21 January 2011, 07:29 »
I will get it sorted at my local garage who does old car refurb work Inc welding :grin:, plus servicing work, don't think he is expensive, he did the following on the wifes golf cab...
 plugs,oil and filter,brake fluid change and brake pads for £50 I supplied all the parts, put me a clutch in it last year for £70....
Thinking these bits Inc welding may be about 80 to 100...
Let u know what he says when I call up in a while :smug:
Thanks for the advice guys, you do keep me thinking it is alll worth while, only done 1200 miles since last Mot and 350 bill
