Author Topic: what is this called (pics)  (Read 2519 times)
Offline swede28
  • <a href="http://www.mybannermaker.com" target="_bl
« on: 19 January 2011, 16:35 »
just wondering what this is called it is a plastic piece with water pipes around it and a sensor i think its a thermostat housing and has a slight leak what is the propper name for it and where would i get one asap as its my daily drive thanks  ps the car is a mk3 golf gti 8v
Offline *Jonnyg*
Re: what is this called (pics)
« Reply #1 on: 19 January 2011, 16:59 »
Has the temp sensor, just go scrappers and get a other 1 mate :) I think they all the same!
** Tuned diesels - kinda like a guy with a huge cock and premature ejaculation. **
Offline Dubbyboy
« Reply #2 on: 19 January 2011, 17:01 »
Not sure of the exact name but I replaced mine recently and it cost around £15 (incl the associated clip and blanking plug) from VW dealer spares
Offline swede28
« Reply #3 on: 19 January 2011, 17:05 »
been around all the scrappys and no mk3,s in any  :shocked:
Offline swede28
« Reply #4 on: 19 January 2011, 17:07 »
will have a drive up tomorrow and see if they have one the leak isnt that bad so can still use the car for now
« Reply #5 on: 19 January 2011, 17:13 »
gsf sell them for dirt cheap, its called a water flange. do the side one at the same time as it wont be far behind if front one is leaking. they comer with new seals plus gsf also do the sensor seals too
Offline swede28
« Reply #6 on: 19 January 2011, 17:30 »
is this the one  part no 179VG0350  WATER FLANGE ON HEAD-SIDE    G3 2.0 8v MPi 11/91 >2/99
Offline leigh_harty
  • Audi AGU
« Reply #7 on: 19 January 2011, 17:54 »
Is it cracked and therfor leaking? or is it the seal thats leaking?... if it the seal then remove, get some sealant round it and then re-fit and should do the job, atleast till a new one is sourced
Dont lose your dinosaur!
Offline swede28
« Reply #8 on: 19 January 2011, 18:08 »
NO IT IS CRACKED WHEN I SQUEEZE THE WATER PIPE I CAN SEE IT COMING OUT OF THE PLASTIC NOT MUCH BUT ENOUGH TO WORRY MY
Offline swede28
« Reply #9 on: 19 January 2011, 18:21 »
 found what im looking for thanks for all the help  :smiley:
