Author Topic: G60 Golf Engine Issue  (Read 2935 times)
Offline Sambob
« on: 18 January 2011, 18:20 »
Hi All I'm New Here!  :smiley:
I have recently finshed doing a G60 Engine Conversion into my MK2. There is a issue which I have currently got it's that whilst the car is under load it seems to Accelerate as it should very quickly from 1,000RPM All the way to 3,500-4,000RPM However once it gets to 4K it seem to not want go anymore than that and splutters and pops struggling to get above. This does happen in the most of the gears and also whilst on full acceleration it seems to let out a fair bit of smoke from the Exhaust...Maybe it's overfueling??
Before this incident in the donor car it drove absolutley brillant pulled very strong right through the Rev range only now this issue has occured. Any advice would be appreciated!
Thanks,
Sam
Offline danny_p
Re: G60 Golf Engine Issue
« Reply #1 on: 18 January 2011, 19:25 »
is it makeing misfireing type noises ?
all the VW's have gone bar 1.
Offline Benrevs
« Reply #2 on: 18 January 2011, 19:33 »
Triple check everything is plugged back in properly. Sounds like fuelling/airflow. Check the maf, and all sensors. Something may not have liked being disturbed.
Offline Sambob
« Reply #3 on: 18 January 2011, 20:00 »
I'd say so when your at 4K with you foot down it does make a misfire sound with a fair bit of popping and banging from the exhaust.
Sam
Offline Sam
  • Sam I am
« Reply #4 on: 18 January 2011, 20:00 »
Sounds awsome to me... not a problem  :grin:
Offline Sambob
« Reply #5 on: 18 January 2011, 20:03 »
Yeah I'm going to take another look at everything tomorrow to ensure nothing has been Knocked out of place or moved. I'm pretty sure it's got somthing to do with the Fueling/Airflow aswell beacuse it mostly seems to happen when i'm on full throtlle.
Sam
Offline Sambob
« Reply #6 on: 18 January 2011, 20:04 »
 :rolleyes: Haha...
Offline danny_p
« Reply #7 on: 18 January 2011, 20:28 »
msfire developing under boost  screams and shouts ignition system as well.  weack coil, cracked dizzy cap or damaged HT lead all worth checking for
Offline Sambob
« Reply #8 on: 18 January 2011, 21:23 »
Cheers for the advice!
I'll go and take a good look tomorrow and report back what the cause was.  :smiley:
Thanks Again
Sam
Offline delirical
  • Like a g60
« Reply #9 on: 19 January 2011, 08:19 »
Sounds like it needs tuning correctly, my g60 ran okish up to 4k and then struggled. Had it tuned- dizzy advanced, co pot adjusted etc etc and now it pulls very well all the way through rev range.
