Author Topic: anti roll bar differences?  (Read 7282 times)
Offline LowlifeDubber
« on: 15 January 2011, 19:37 »
so it's just dawned on me while having a poo au work.that ive upgraded the brakes.changede the back axle coilovers are on all bushes replaced and then i realised i must have a sh!t anti roll bar.the car is a 1.8 driver 93.do the mk3's have different size anti roll bars?if so what do i need a vr6 one?and is it just a case of changing the tie bars and mounting brackets or is there more to it?its 4 stud if that make a difference.i will poly bush it as i go if it need's changing.it will have a vr6 jump in it soon so dont worry about weight issues.hm on my phone incase you were wondering why i round like a tard.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: anti roll bar differences?
« Reply #1 on: 15 January 2011, 23:04 »
I thought the GTI's / VR6 ones were slightly thicker...but then i could be the person that's wrong here? :undecided:
« Reply #2 on: 15 January 2011, 23:08 »
IIRC the standard GTI ones are 20mm and a lot of the upgraded aftermarket ones are either 25 or 28mm.
« Reply #3 on: 16 January 2011, 20:03 »
Hmmm ive been looking at bushes for then and they do 18mm or 20mm i will have to go get the vernier out after work in the morning and have a look see.only another 11hours to go lol
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 16 January 2011, 20:37 »
driver will be 18mm and gti as stated is 20mm (and to fit a gti bar you need the arms too!)
« Reply #5 on: 16 January 2011, 21:57 »
Ahhh great stuff thanks.So if i get the anti roll bar 2 track control arms and the brackets underneath that will do me then?does it matter that im running 4 stud as im sure ive read somewhere that the 5 stud wishbones are a little wider.It looks a pain to do too but it will bug me if i dont do it! :angry:
« Reply #6 on: 18 January 2011, 10:30 »
you cant fit a mk3 gti bar without changing the wishbones and the bearing carriers which means goign 5 stud.  fit an uprated MK2 golf/corrado 4 stud one instead, G60 bar is 23mm.  SEAT Ibiza/toledos have 20mm+ as well, get down scrappy and have a look
« Reply #7 on: 18 January 2011, 15:02 »
Aaaah nice one RJ i was hoping you would see this :grin:
So if i go for an uprated G60 affair im looking at just changing the front drop links and the 2 brackets underneath?
« Reply #8 on: 18 January 2011, 15:51 »
with the g60 bar the inner brackets and bushes are the same as the 18mm ones, just the outer drop links need doing. the other vag bars may need the inner bushes changing, depends what you get hold of :)
« Reply #9 on: 18 January 2011, 18:09 »
Superstar,cheers mate :)
