Author Topic: Roof aerial seal UPDATE steam gone :)  (Read 3667 times)
Offline Dan_GTi8v
« on: 15 January 2011, 16:34 »
Anyone know where I can get a seal for the base of the roof mounted aerial? Inside of the car is getting steamed up so I'm looking for a leak somewhere and am thinking it could be the aeriel. cheers :)
« Last Edit: 02 February 2011, 19:51 by Dan_GTi8v »
Offline AlexMozza
Re: Roof aerial seal
« Reply #1 on: 15 January 2011, 16:37 »
Breakers, GSF?
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
« Reply #2 on: 15 January 2011, 19:37 »
Doubt it is the aerial, check the rear lamps and the sunroof drains if you have one fitted.
« Last Edit: 15 January 2011, 23:34 by Wayne »
Offline Stirring Moose
« Reply #3 on: 15 January 2011, 21:43 »
I cut a new seal from black rubber sheet and finished the job with a carefully applied smear of sealant. Ultimately it's a bodge but it does the job and you'd have to be a bit keen to spot it even if I do say so myself!  :smug: Might also be able to something similar with an o-ring or some other type of seal.
S.M.
Love and hate, war and peace, joy and sadness... all just crap that happens between trackdays!
« Reply #4 on: 15 January 2011, 23:34 »
S.M.
I used part of a old inner tube for mine, worked all ok.
Offline coilpack
« Reply #5 on: 16 January 2011, 10:20 »
I doubt a water leak would allow the windows 2 steam up.... I would say your heater core is leaking ???
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 16 January 2011, 10:42 »
If your sure it's the seal (which do commonly fail and do cause condensation!) then find a big hella dealer as you can buy all the aerial bit's separate (or maybe try ebay?)
Offline tweed
« Reply #7 on: 16 January 2011, 11:19 »
I haven't got a seal  :laugh: it doesn't seem to be leaking so not a big problem, however I do want to replace it.
How do I get it off to replace the seal? thank you
Offline dom
  • Back in a Mk4
« Reply #8 on: 16 January 2011, 12:47 »
Sorry but that is bullsh!t. Condensation on windows is caused by water in the car, a leaking rear light seal would certainly allow enough water into the car to cause condensation. There is absolutely nothing to suggest that the heater matrix is leaking :rolleyes:
Offline Len
« Reply #9 on: 16 January 2011, 13:30 »
To get off you have to release the headlining at the rear. Then its just one nut.
www.sas.org.uk
www.the-ace.org.uk
