Author Topic: hmm  (Read 2117 times)
Offline chris_vw_1987
hmm
« on: 15 January 2011, 09:44 »
« Last Edit: 04 June 2011, 12:54 by chris_vw_1987 »
2001 Volkswagen Golf 1.8t - AUM
Re: 2001 AUM Electrical Problems ?!?!
« Reply #1 on: 16 January 2011, 14:32 »
Anyone ?  :sad:
dellenty69
« Reply #2 on: 16 January 2011, 14:47 »
under the steering wheel are lots of relays and a few extra fuses.
check your headlight and flasher relay.
« Reply #3 on: 16 January 2011, 15:38 »
Ok, do you know what number the relay is? ... and how do you safely remove trim and get to the relays :)
Offline richw911
« Reply #4 on: 16 January 2011, 15:44 »
http://www.golfgtiforum.co.uk/index.php?topic=87372.0
« Reply #5 on: 25 January 2011, 18:32 »
Eek, its got worst in the wet, ABS and traction control lights come on..
Does anyone know where all the earth points are on the car? I have a whistle noise coming thru the stereo
Offline new to vw
« Reply #6 on: 25 January 2011, 20:46 »
There should be an earth point under the battery if i remember right...???? :grin: :grin:
5 door 1.8t AUM
Offline T_J_G
« Reply #7 on: 25 January 2011, 21:14 »
Check the fuses on top of your battery.
« Reply #8 on: 26 January 2011, 13:14 »
Will go out and check that now... brb :)
« Reply #9 on: 26 January 2011, 14:53 »
The 3 Green fuses are fine, there very clean...
