Author Topic: CV Joints  (Read 2277 times)
Offline Khare
  • The bear that khares
Re: CV Joints
« Reply #10 on: 15 January 2011, 16:12 »
My bad I read it wrong, thought you said hub won't go back on.
If the nut doesn't go back on you can stick on any nut (that fits and tightens obviously) as a temporary measure. Mine had a normal nut on there until I found out and swapped it.
Offline AlexMozza
Re: CV Joints
« Reply #11 on: 15 January 2011, 16:13 »
It will, but its really tight, looks like the thread is a bit f00ked, was hard to get it of too though :/ Thread on the Shaft is fine though :/
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline AlexMozza
Re: CV Joints
« Reply #12 on: 15 January 2011, 16:16 »
You dont happen to know what thread it is eg M8x1.25 ect :)
2001 Satria GTi
Formula 3 Mechanic
Offline Khare
Re: CV Joints
« Reply #13 on: 15 January 2011, 16:19 »
Don't force it then, you might end messing the shaft thread up and causing more expensive damage than just a bad nut.
Do what I said, so you can drive to a car parts place and get a shaft nut or just get one online and wait a few days.
No idea what thread it is mate, sorry! (30mm socket required though)
http://www.vwspares.co.uk/product_info.php?products_id=1687
And this sort of nut
http://www.vwspares.co.uk/product_info.php?products_id=564
Offline AlexMozza
Re: CV Joints
« Reply #14 on: 15 January 2011, 16:21 »
Coolio, Nope i've just left it. Thought i might of had the right size tap but no luck!
Where did you get the bolt from, B&Q ect?
2001 Satria GTi
Formula 3 Mechanic
Offline Khare
Re: CV Joints
« Reply #15 on: 15 January 2011, 16:24 »
Well I bought that kit I linked you too which came with the bolt. Nut( :grin:) sure where to buy it from on it's own, but my first guesses would be GSF and ECP.
Offline AlexMozza
Re: CV Joints
« Reply #16 on: 15 January 2011, 16:26 »
The kit i got did not have one :( Oh well, no MoT on monday :/
2001 Satria GTi
Formula 3 Mechanic
