Author Topic: CV Joints  (Read 2273 times)
Offline AlexMozza
CV Joints
« on: 14 January 2011, 21:45 »
I need to replace my N/S outer CV Joint gator, How hard is this job to do :)
My Local garage (Non VW) quoted £150 :o
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline Khare
  • The bear that khares
Re: CV Joints
« Reply #1 on: 14 January 2011, 22:38 »
Blimey £150  :shocked:
It's a pretty easy job, just be careful the joint doesn't fall apart. You need the socket to remove the hub nut, then you need to remove the bottom ball joint and pull the hub away. From there on it's a question of removing old gaiter and CV joint, cleaning it up, regreasing it and refitting it all up. Took me about an hour from start to finish.
Offline AudiA8Quattro
Re: CV Joints
« Reply #2 on: 14 January 2011, 23:56 »
1 hour? you done well.
Its easiest to remove the driveshaft complete.
Loosen the hub nut, remove the inner flange spline bolts.
As already stated, remove the bottom balljoint to give you enough room to get the driveshaft out of the hub.
Now the hard bit, every mk3 gti/vr6 i have worked on, i have needed a puller to remove the shaft from the hub.
On the plus suspension locktite was used, and its a very tight fit.
Once removed, cut off the old gaitor. The joint will come off when you hit it with a rubber mallet, best to clamp the driveshaft first.
Keep a note of the position of the washers when it comes apart.
Re-assemble, then refit the shaft.
Re: CV Joints
« Reply #3 on: 14 January 2011, 23:58 »
Oh yes and don't forget to clean out old grease and fill joint and gaitor with new grease!!
Offline Khare
Re: CV Joints
« Reply #4 on: 15 January 2011, 00:02 »
No need to remove the drive shaft when I did it, hub came away from shaft pretty easily, a bit of force but nothing too hard.
Make sure when you hit the joint to get it off, the inner joint doesn't get pulled out too much or it'll disassemble (if you do do it with the driveshaft in).
Use white spirit or petrol to clean out the old grease.
Oh and it can be a right pain getting the new clips on tight, so if you an stretch it, buy the clip tool.
Re: CV Joints
« Reply #5 on: 15 January 2011, 00:07 »
The mk3's i've worked on with plus suspension, the driveshaft was stuck solid in the hub.
There was no moving them without a puller, which is what the bentley manual says is required.
Obviously on some cars its doesn't seem to be required, i don't know why.
Offline Khare
Re: CV Joints
« Reply #6 on: 15 January 2011, 00:15 »
Yeah, every car is different to work on I find. Where as two of the same aged cars and same spec should be the same, there's always one that has issues with getting bolts out or this or that.
Offline AlexMozza
Re: CV Joints
« Reply #7 on: 15 January 2011, 03:10 »
Thanks for that guys :)
Ill try it with the shafts on first, then failing that its of with the shafts!
2001 Satria GTi
Formula 3 Mechanic
Offline AlexMozza
Re: CV Joints
« Reply #8 on: 15 January 2011, 15:59 »
All done, just need a new hub nut as mine wont go back on :(
Anyone got one????? - TBH this is pretty URGENT :'(
2001 Satria GTi
Formula 3 Mechanic
Offline Khare
Re: CV Joints
« Reply #9 on: 15 January 2011, 16:08 »
How will it not go back on?  :huh:
What doesn't fit?
