Author Topic: mk2 front subframe removal  (Read 11974 times)
Offline bosco
« on: 11 January 2011, 20:32 »
Just wondering does anyone have a step by step guide or something to removing the front subframe off a mk2? I am doing an engine conversion and rather then just remove the engine and box i want to remove it all at once as a 1.8t is going in with g60 brakes and all etc? Its a 1990 reg and im looking to drop the whole subframe out so i can bolt the other one in. Thanks for tips in advance :)
1990 mk2 1.6 daily
1990 20v turbo project learning as I go
Offline Ben Lessani
Re: mk2 front subframe removal
« Reply #1 on: 11 January 2011, 23:44 »
Its about 6 bolts - which are all fairly obvious to see.
Best buying a Haynes buddy.
Offline Sam
  • Sam I am
« Reply #2 on: 12 January 2011, 00:20 »
Eye its 6 bolts, three at the far end of each side. Just remember it has two mounts attached to it, the gearbox and rear engine
edit, sorry i thought it said rear. The front is again three bolts, the middle one holds on your front bumper and the outer two hold on the subframe. So obv take out the middle bolt first on each side or you will end up with a bumper on your head. Make sure you jack the engine or the whole thing will simply tip forwards and squash your head
« Last Edit: 12 January 2011, 00:23 by caistor_bmx »
Offline bosco
« Reply #3 on: 12 January 2011, 00:44 »
haha i may make sure i support the engine then i dont want to lose my good looks  :laugh:
1990 mk2 1.6 daily
Offline Sam
  • Sam I am
« Reply #4 on: 12 January 2011, 00:49 »
I would double support it If i were you, before removing my front bumper i have to check the other four bolts as when you are under the car you can just see the engine perched above your head  :grin:
Offline bosco
« Reply #5 on: 12 January 2011, 00:53 »
im gonna stick the engine crane around it tomorrow would that be enough to support it and a trolley jack? what about disconnecting the steering rack? is that just pull up the rubber sleeve and do the bolts?
1990 mk2 1.6 daily
Offline Sam
  • Sam I am
« Reply #6 on: 12 January 2011, 01:01 »
You have power steering?
Offline bosco
« Reply #7 on: 12 January 2011, 01:03 »
yep have the pump/resevoir and lines disconnected but was wondering about the rack thats attatched at the back of the engine would that have to be disconnected?
1990 mk2 1.6 daily
Offline Sam
  • Sam I am
« Reply #8 on: 12 January 2011, 01:05 »
To remove the front subframe or the entire engine?
Offline bosco
« Reply #9 on: 12 January 2011, 01:08 »
both really. wanna drop the front subframe with engine and box out of the car?
sorry im probably not explaining it right
« Last Edit: 12 January 2011, 01:09 by bosco »
1990 mk2 1.6 daily
