Author Topic: mk2 front subframe removal  (Read 11968 times)
Offline Sam
  • Sam I am
Re: mk2 front subframe removal
« Reply #10 on: 12 January 2011, 01:16 »
I think I kinda get what your talking about, the easiest way to do it would be to disconect the drive shafts from the gearbox, undo the gearbox mount and the rear engine mount and the front engine mount without toutching the subframes and lift the engine and box out together (dis connect your gear linkage too and clutch cable ect ect ect obv). Then undo whatever you want subframe wise  :laugh: I have only ever taken out a vr engine so that involved removing the gear box as its super heavy block but same principles apply
« Last Edit: 12 January 2011, 01:18 by caistor_bmx »
Offline bosco
« Reply #11 on: 12 January 2011, 01:19 »
Ok cool cause i was told to just undo the subframe and just drop everything out on it, wheel it off and just do the same with the other then just put it back in?
1990 mk2 1.6 daily
1990 20v turbo project learning as I go
Offline Sam
  • Sam I am
« Reply #12 on: 12 January 2011, 01:23 »
Ah ok I see, so rather than lift you wanna pull? So your slam panel is off and everything? In that case yer just do your rear mounting bolts and the 6 on the subframe and wheel her out
Offline bosco
« Reply #13 on: 12 January 2011, 01:25 »
haha i made a balls of explaining that then my bad. Yeah thats the plan anyway. Thanks for the Help Caistor appreciate it dude
1990 mk2 1.6 daily
Offline Sam
  • Sam I am
« Reply #14 on: 12 January 2011, 01:28 »
No worries  :laugh:
Offline Ben Lessani
« Reply #15 on: 12 January 2011, 09:40 »
have a look at the first page of my dub project (click my sig link) and select engine removal from the contents
Offline danny_p
« Reply #16 on: 12 January 2011, 11:52 »
to do 20vt it is easyest to remove the frount pannel and drop the subframe imo.  as it dosent take long to do and just makes accses so much easyer for the multitude of small taks that have to be done as well.
all the VW's have gone bar 1.
Offline bosco
« Reply #17 on: 12 January 2011, 12:49 »
thanks guys im gonna drop it today  :grin:
1990 mk2 1.6 daily
Offline Sam
  • Sam I am
« Reply #18 on: 12 January 2011, 12:50 »
Get off the facking internet then and get outside. Also take lots of pics and do a project thread  :smiley:
EDIT, Removed the bumper on mine today and realised that its the outer two bolts you need to remove, then your engine is only held in by the inner smaller single bolt. Now I remember why it was so scarey
« Last Edit: 12 January 2011, 16:22 by caistor_bmx »
