Author Topic: Please Help - Engine Speed / Crankshaft Position Sensor Location  (Read 1316 times)
Offline GCGTI
Can anyone please tell / show me where the engine speed / crankshaft position sensor is on a mk3 gti 2.0ltr 8v engine code ADY.
I have read several threads and cant find a conclusive answer.
Please help asap as car of the road and I think this is the solution??
Thanks
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
It's located just behind the oil filter/ oil cooler at the front of the engine block. They have very restricted access so it's advisable to remove the front engine mount bracket to get a good hold of the tiny hex cap headed bolt.
« Last Edit: 11 January 2011, 21:12 by thai-wronghorse »
Offline N900 MJT
It's located just behind the oil filter/ oil cooler at the front of the engine block. They have very restricted access so it's advisable to remove the front engine mount backet to get a good hold of the tiny hex cap headed bolt.
+1
Did mine a couple of months ago - really easy once the front mount is out of the way
Offline javalin
+1 - easy enough
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
