Author Topic: oil consumption judder on tick over  (Read 2779 times)
Offline pm
« on: 20 February 2005, 21:50 »
can  anyone please confirm how much oil my x pllate golf gti 2.0 litre should be using  after  oil and filter change three months ago  oil light has now come on  and dipstick was low.approx 2000 miles covered.no obvious external leaks emissions ok,is this just general consumption.golf garage cannot find a fault.just concerned never had to put oil in on a reg basis.
also judder on tick over when 800 revs no probs when starting engine at 1000 revs again no garage fault found mechanics state normal for car type.
any advice welcome
Offline rtking449
  • Run out Mk2 8v GTI &MkIV Tornado Red GTI
Re: oil consumption judder on tick over
« Reply #1 on: 20 February 2005, 21:53 »
Ive got a Mk4 2 litre and that is heavy on oil with 55000 on clock using synta gold,may change to silver next time!
Offline pm
« Reply #2 on: 20 February 2005, 22:00 »
thanks done 62000 just concerned incase  major cost
Offline pm
« Reply #3 on: 01 March 2005, 13:14 »
anyone else had same complaint now smelling funny and giving off smoke when starting still drives fine
[/q uote]
Offline rtking449
« Reply #4 on: 01 March 2005, 14:15 »
What do you mean smells funny?Oil,petrol or what?
If I was You i wouldnt be using the car until it is checked out properly
Is there any good independent VW specialists near you?
Offline Bullitt
« Reply #5 on: 04 March 2005, 19:23 »
Sorry to tell you guys but the MK4 2.0 GTI suffers from piston ring wear after 50k :cry:
Obviously the VW dealer will deny it!!? But a mate is a VW master tech!!
Use 15/40 for higher mileage engines
As for the judder!! Remove the throttle body and clean it with a cloth and carb cleaner..
« Last Edit: 04 March 2005, 19:28 by Bullitt »
Offline pm
« Reply #6 on: 08 March 2005, 14:20 »
thanks cleaned throttle was dirty still get judder everyone saying normal for car  when revs 1000 no judder still drives ok.
vw stating engine OK  got me worried about piston rings how will i know for def.
Offline 16v Matt
« Reply #7 on: 09 March 2005, 14:45 »
Thats shocking for a newish car!!! :shocked:
Offline Bullitt
« Reply #8 on: 13 March 2005, 02:53 »
VW stating engine OK?
Told you so!! Its a known fact at 50k+ they use oil!!! :huh:
Offline E105
« Reply #9 on: 14 March 2005, 11:36 »
I have been told that it common to use a litre between servicing, though it certainly shouldnt be juddering.  My old MK4 did use up to that between services but seemed saound apart from that.  Check out the breathers as well as they seem to get clogged up duuring the winter.   I was told by my maindealer that aircon units are supposed to make noise, 6 months later the bearings failed and was all repaired under warrenty.
If in doubt get it checked independently.
