Author Topic: headlamp washers  (Read 3160 times)
Offline golf1.8t
headlamp washers
« on: 20 February 2005, 20:11 »
does anybody no if/how to put headlamp washers on as i have got an r32 front bumper and it has the holes for the headlamp washers but my car does not have them as standard would it be a big job to fit and make them work and a rought price of how much it would cost any help would be very helpful.
DUBBIN FOR LIFE:
Offline Dizzie
  • Make friends with your fast
Re: headlamp washers
« Reply #1 on: 21 February 2005, 10:47 »
shouldn't be too hard a' job if you had the motors, etc. just add a relay to turn them on as well as squirting the screen. if that's how they work, I dunno?
Mk4 Golf 150PD
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 21 February 2005, 11:50 »
Most people simply bond the washer caps to the bumper, in a sort of "ive got headlight washers/xenons" look-a-likey stylee.
Offline 4 motion
« Reply #3 on: 21 February 2005, 13:04 »
I have them on mine and they only work with the headlights on so there must be
a link between headlights being on and the washer pump being told to operate.
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #4 on: 21 February 2005, 15:34 »
On most cars they only work when the lights are on - so the supply is energised via a relay connected to the headlight circuit.
You also need to think about where the water will come from - on some cars they use the same water supply as the windscreen washers - on other cars I have owned, they used a seperate tank.
I would imagine that its quicte and easy job, if you have the wiring diagram (if needed) and all the necessary bits.
Best bet is to speak to a breaker who has an R32 (or another model with H/lamp washers in). Probably get a reasonable deal on the whole lot, and if you can go and remove the biots from the car, you can take notes/photos whilst you do it, so you know where to route everything onyour car. You might even get a mini-loom for the whole job, and it might turn out to be a simple plug n play job.
Good luck bud
The greatest leveller of them all - the Carousel
Offline R32_T
« Reply #5 on: 21 February 2005, 20:57 »
If you don't want them, just stick the headlamp washer caps over the holes so it looks like you got them.
2001 20V Turbo        1997 VR6 Highline
"Granny shifting not double clutching like you should"
Offline golf1.8t
« Reply #6 on: 21 February 2005, 21:08 »
were did you get your from mate and what sort of price were they
DUBBIN FOR LIFE:
Offline R32_T
« Reply #7 on: 21 February 2005, 21:37 »
As i said in the pm I sent you mate, I already had them as standared
Offline golf1.8t
« Reply #8 on: 18 March 2005, 20:30 »
found headlamp washer caps www.vagpart.com ?5.92each and i got the jets as well ?13.96each and a set of r32 bumper grillls ?16.95 plus vat
DUBBIN FOR LIFE:
Offline bosun
« Reply #9 on: 22 March 2005, 07:54 »
It isn`t that hard to fit them properly.You need.- Jets/Covers/Washer bottle/Piping/Washer pump/Connectors for piping and a headlight washer relay.My mate got pipes, bottle and pump from a breakers for ?20.I have got to have a look to see if the wiring is there,which i doubt,but not problem as the relay can be fitted down by the headlight and wired so it will work as intended.
