Author Topic: Vagcom tweaks  (Read 7933 times)
Offline Jimble
Vagcom tweaks
« on: 09 January 2011, 22:44 »
Has anyone that has done any tweaks with Vagcom had any problems afterward? The reason i ask is i would like to get a couple things changed, mainly dial staging, deactivate auto rear wiper and auto window closure when it rains. I know a few on here have done some bits and bobs but does it ever bugger anything up?
Offline The Doc
  • E63s Estate - Vito Sport
Re: Vagcom tweaks
« Reply #1 on: 09 January 2011, 23:05 »
Only if it's done by an idiot  :smiley:
Where are you based?
Offline Jimble
Re: Vagcom tweaks
« Reply #2 on: 09 January 2011, 23:21 »
I'm not far from birmingham mate but i should be having a run up to Darren's on saturday to get bluetooth fitted all being well, so was going to ask him to do it for a few beer tokens, tbh it's my missus that has put doubt in my mind about problems if the car has to go in for anything. :undecided:
Have you done the staging thing cos that and the rear wiper is what i'd like doing most?
Offline The Doc
Re: Vagcom tweaks
« Reply #3 on: 10 January 2011, 12:52 »
Not the staging as it's not for me but yes I've done the wiper and done a "how to" on it, Darren knows what he's doing so you'll have no problems there.
Re: Vagcom tweaks
« Reply #4 on: 10 January 2011, 14:19 »
Yeah, that rear wiper is a good one I reckon. It really pee's me off when I'm reversing and the wiper decided to scrape accross a dry bit dirty screen leaving a right mess  :angry:
Must look into getting that one done myself.
Offline Jimble
Re: Vagcom tweaks
« Reply #5 on: 10 January 2011, 17:32 »
Just had a look at your how to mate, what do byte 2 and 3 do?
Offline Keithuk
Re: Vagcom tweaks
« Reply #6 on: 10 January 2011, 21:46 »
Well I've only just bought myself VCDS for Christmas so I haven't done much with it at the moment apart from a couple of autoscans that bring up a couple of faults and I've extended the heated rear window/mirror timer from 10 to 14 minutes.
There are tweaks on other forums I noticed one the other day VCDS MKVI / MK6 Platform, Handy Coding tweaks setup by Dana from Ross-Tech. I know its a TDI forum but a lot of tweaks are common to all models.
To be honest I find the help crap on VDCS as there isn't any apart from the basic setup pdf. I'm trying to get the TDI forum I use the most to have a VCDS/VAG-COM section  :wink:
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline Jimble
Re: Vagcom tweaks
« Reply #7 on: 10 January 2011, 21:51 »
What kind of faults Keith? From something you've had done or just issues with the car itself?
Offline Keithuk
Re: Vagcom tweaks
« Reply #8 on: 10 January 2011, 22:25 »
No I've done nothing to it only the heated rear window timer last weekend.
I did an autoscan after Christmas and it showed
03-ABS Brakes -- Status: Malfunction 0010
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Fault Frequency: 1
Mileage: 8041 km
Date: 2010.14.04
I don't know why it shows the current mileage and last years date when it wasn't at the dealers or is that when the fault first got logged?
09-Cent. Elect. -- Status: Malfunction 0010
1 Fault Found:
00897 - Windshield Washer Pump (V5)
012 - Electrical Fault in Circuit - Intermittent
The washers have always worked perfectly. I decided to clear all faults and autoscan it again last weekend. After clearing it still shows
03-ABS Brakes -- Status: Malfunction 0010     [both in red]
But No fault code found. on all systems.  :wink:
Offline The Doc
Re: Vagcom tweaks
« Reply #9 on: 11 January 2011, 08:25 »
The date tends to be wrong a lot of the time Keith, I can't say why, I'd suggest asking on that forum but you know where that ends up  :rolleyes:
I know that you'll know thus but if you look in Mk6 Maintenance there's a stcky on VCDS tweaks - would you like your own vcds section in there or maybe in the MK6 TDI section?
It would be quite good for you to do a blog as you go along explaining what you've done, where you've found help and what your struggling with, if you have the time of course :-)
Typing on my IPhone so please forgive the spelling.
« Last Edit: 11 January 2011, 08:32 by The Doc »
