Author Topic: golf mk1 .1.8t wiring  (Read 9369 times)
Offline lord14
« on: 08 January 2011, 20:51 »
only thing im stuck on any one with guides or help ?
« Last Edit: 11 January 2011, 18:34 by SoundillusioN »
Offline SoundillusioN
Re: golf mk1 .1.8t wiringh
« Reply #1 on: 09 January 2011, 22:29 »
Hmmm, you best hope rubjonny see's this one... he's very good with these things.. not something I know anything about. might help posting some infor on your setup, are you using the orginal loom and ECU?
Offline Sam
  • Sam I am
« Reply #2 on: 10 January 2011, 03:08 »
I swear one day jonny will of had an influence on the wiring of every pre 90 vdub
« Reply #3 on: 10 January 2011, 12:06 »
what ecu are you using?
Offline lord14
« Reply #4 on: 10 January 2011, 17:05 »
standard agu ecu, whihc has been fuly decoded , cheers rob
« Reply #5 on: 11 January 2011, 10:03 »
http://vwtech.no-ip.info/downloads/g4aguecu.pdf
what type of fusebox do you have, early ceramic or late blade?
Offline lord14
« Reply #6 on: 11 January 2011, 17:31 »
not sure on whichone it is to be honest , how can i tell ? and that diagram i dont understand. im stuckk on the 4 pin plug near the starter motor and a plug whihc goes under the battery tray on the mk4
« Reply #7 on: 12 January 2011, 10:03 »
read this:
http://www.golfgtiforum.co.uk/index.php?topic=90707.0
it'll take a while before you get your head round it but eventually you'll figure it out :)  Txx are plugs, with some detective work you can figure out which T refers to the 2 plugs you are on about. Though I think its T4 (see page 2) and T10a (see page 3)
check also my fusebox faq, has pics of the front of the later blade fusebox (CE1 pic on page 2)
http://www.golfgtiforum.co.uk/index.php?topic=44637.0
Offline lord14
« Reply #8 on: 12 January 2011, 16:35 »
theres only one pagge on the first link :/ and how do i read them diagrams ?
Offline lord14
« Reply #9 on: 12 January 2011, 16:38 »
looks to be the ce1 fuse box i have
