Author Topic: Drivers Door will Central lock but not unlock??  (Read 1155 times)
Offline bmouthboyo
« on: 08 January 2011, 15:26 »
Hi,
During the cold snap my Central locking on the drivers side seems to have picked up a fault.
Basically it will 8 times out of 10 lock the car centrally (boot driver and passenger locks) however it will not unlock them or indeed itself, although the key does turn both ways freely.
I have to unlock the car using the passenger door, this unlocks them all centrally.
So I assume it is local to the drivers door. It almost feels as if there is too little resistance, and i have to turn it a few times before it registers and locks the car.
Dodgy connections? Lock?
Thanks
Offline bmouthboyo
Re: Drivers Door will Central lock but not unlock??
« Reply #1 on: 08 January 2011, 22:09 »
To add detail when I turn the key to lock the when it doesn't work it does not make the whirring noise, to unlock it never makes that noise. Could it be a faulty connector?
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #2 on: 08 January 2011, 22:32 »
Im going to hazzard a guess the door handle is damaged mate
i had the same issuse (or at least similar)  on the lock mech their is a small bit that engages the rest of the mech, this part is on the handle and it snaps, im guessing the cold and the force u may have put on unlocking the car has snapped it, the bit that breaks is about a CM long  and a few mm wide, id whip the handle off and check, and if you have or can get a spare handle try it, (you can easy swap out your lock into the new handle or get a handle off a rear door and go delocked route) either way i think u need a new handle or at least rob the bit off another handle..  but theirs 2 variations of handles and they are a little different to each other meaning the internal bits cant be interchanged... in that case u would have to swap the whole handle (again - u can still put your existing lock barrel in any easily)
hope that makes sense!  :cool:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline bmouthboyo
« Reply #3 on: 08 January 2011, 22:37 »
Ah I think I understand
But isn't it odd that it works intermittently with the locking the car, but not at all unlocking.  :laugh:
Is it easy to remove the handle?
Thanks
Offline F17BAD
« Reply #4 on: 08 January 2011, 22:51 »
yeah its odd, it could be just damaged and not yet fully broken like mine did, the bit i mean is mad eof cast sh!tty metal, nickle plated colour (wish i could show u a pic)
its the bit that hooks to the mech fromthe handle
to remove handle is easy, their is 1 screw on the inner edge of the door, undo this and ease the handle out but dont yank, as this will deffo damage the bit im on about
