Author Topic: ENGINE IDEAS FOR MK3 2.0 8V GTI TRANSPLANT?!?!??!?!  (Read 9266 times)
Re: ENGINE IDEAS FOR MK3 2.0 8V GTI TRANSPLANT?!?!??!?!
« Reply #50 on: 11 January 2011, 23:45 »
Did you pick up Golf+ this month? It had a big spread on engine conversions in there - 1.8T, R32, 2.0TFSI etc. Might help you with your decision.
Lets be honest for a second or 2, to get a 2.0 TSFI in and working is beyond a diy job plus you need to find a doner car and I would suspect by the time it is finished you will have knocked a hole in £5k +
TSFS beyond a DIY job, nope. QPENG are making a Plug and play loom for the mk1,2 and 3 :evil:
Still got to sort the fuel system etc, still cannot see it being easy.
But they have made it a hell of a lot easier.
Guess so but I am not keen on qpeng, removes too many safety features for me.
Offline Dan_GTi8v
« Reply #51 on: 12 January 2011, 04:58 »
What you get for the money from QPeng is pretty poor, an ECU with 90% of the standard safty features plus a loom you have to supply them with gets a few wires spliced in for a grand. No thanks!
Get yourself a standard ecu and loom from a 1.8t and mod it yourself (guides are around, theres a good one on ClubGTi with pics and easy to follow instructions) or there are people on here who can mod it for you for around 300, if you wanted it mapped aswell as long as you get it cheaper than 700 you are cheaper or equal to QPeng plus you have a much better management system and none of the hassle that comes with running custom management (like garages not wanting to touch you with a barge pole etc)
Offline LazyLunatic
  • MK3 20VT Project
« Reply #52 on: 12 January 2011, 08:54 »
I agree to a point, hence why I'm using standard management with Stu's car. But I don't see the big problem with QPeng, its fine to use and I don't think people should slate it, its a quality bit of kit and they try to help with any problems you have.
Given, its expensive and that's the mostly the reason why we and many other's now choose to run the standard ECU and the fact its easier with all the help available too.
Alex :)
Offline Dan_GTi8v
« Reply #53 on: 12 January 2011, 15:44 »
I'm not slagging off QPeng at all I've not heard of too many problems and certainly not any more than people who run other managements, and they are pretty helpfull with any issues you have. Just think its not worth near £1000 :)
Offline sharki786
  • GOT BOOST??
« Reply #54 on: 12 January 2011, 16:44 »
bi-turbo vr6!!!  :cool: now thats the way 4wrd!  :evil:
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #55 on: 12 January 2011, 16:46 »
Would not work on a VR as you only have one bank and manifold.
Offline sharki786
  • GOT BOOST??
*****MK4 GTI T*****
Offline archie837
« Reply #58 on: 12 January 2011, 22:26 »
Anyway mate. Golf + had loads of info on engine swaps this month. Think it was part 2 too, so if you can get hold of last months issue it might have other options as well as the modern lumps.
Project longterm Airbanger.
PD150 Anni daily
Offline Dan_GTi8v
« Reply #59 on: 13 January 2011, 00:46 »
1.8t is the easiest and most cost efficient way to get better performance out of a mk3 :)
