Author Topic: Welding Wheels has cropped up a few times now  (Read 2334 times)
Offline Martz
« on: 06 January 2011, 21:29 »
So for all of you who want to read -
http://www.ukwelder.com/forum/index.php?showtopic=7117
I can believe that an alloy needing welding and deemed as scrap by most 'garages' and then repaired can invalidate insurance. Would like to know more about this as it seems a very untouched area, ie, what happens if the wheel fails and is deemed the cause of a fatality in a RTA? Who gets put up for manslaughter? :huh:
« Last Edit: 07 January 2011, 08:26 by Martz »
Offline tech1889
  • Mk2 GTI FTW !!
Re: Welding Wheels has cropped up a few times now
« Reply #1 on: 06 January 2011, 21:31 »
on a £200 set of alloys i would just bin the bad ones.. but on a set of bbs's for instance that cost like 3k new i would wana try my hardest to get em repaired..
« Reply #2 on: 06 January 2011, 21:38 »
I can believe that an alloy needing welding and deemed as scrap by most 'garages' and then repaired can invalidate insurance. Would like to know more about that as it seems a very untouched area, ie, what happens if the wheel fails and is deemed the cause of a fatality in a RTA? Who get put up for manslaughter? :huh:
It would be the owner of the company that repaired the wheel.
Offline Peej1981
  • Its Whats Under The Hood That Counts........
« Reply #3 on: 06 January 2011, 21:51 »
This is exactly my point that i made in the banded alloy thread. This is why i would have it done properly where they check it after and certify the wheel is safe.
www.bombercountydubs.co.uk
Offline Martz
« Reply #4 on: 06 January 2011, 22:07 »
A family member of mine works in the oil and gas industry and we were talking about welding the pipelines. Their are so many checks that they carry out to ensure that the pipes are welded to tight regulations. A pipeline has extreme pressure and stress.
All I am suggesting is that is no industry standard that can regulate bad repairs. May look good on the outside but a bit of contamination could be the end for someone further down the road!
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #5 on: 06 January 2011, 22:12 »
thats a risk each individuall is willing to take tho isnt you put that wheel back on at your own risk..  a brand new wheel is likely to have defects and could fail as well.. Its just a risk we run..
Offline Martz
« Reply #6 on: 06 January 2011, 22:19 »
Not really, with new wheels oem and manufacturers, they have set quality standards in place................................
« Last Edit: 07 January 2011, 08:27 by Martz »
Offline dan_apps
  • too low for british roads!
« Reply #7 on: 06 January 2011, 22:31 »
with the banded wheels if doing it through a reputable company the weld will be certificated after testing, this is the only route i would personally take. welded alloys just plain sound iffy to me.
just found this:
http://www.alloywheelrepairs.net/Welding.html
very clean in their workshop i must say! :lipsrsealed:
no mention of certification though.
Offline Martz
« Reply #8 on: 06 January 2011, 22:35 »
It's the image on the front screen that terrifies me to be honest.
Offline bmotormad
« Reply #9 on: 06 January 2011, 23:07 »
I would never drive round on a rim that had suffered this much damage and it scares me to think that there is some old bloke in his dirty shed churning out accidents waiting to happen. If someone i know had a rta because of a repaired wheel his insurance would be the last thing on his mind !!! :angry:
http://www.alloywheelrepairs.net/Content/Images/Photo%20Gallery/Wheels%20Damaged/AWR-040605-%20003.jpg
