Author Topic: vr6 coolant leak  (Read 1514 times)
Offline forsh
vr6 coolant leak
« on: 06 January 2011, 09:57 »
been looking around my car and seen some coolant on the snow
and notice i have to fill my colant up atleast once a month,just about half a liter
what could it be
i also noticed the coolant cap thing is really hard to unscreww
Offline forsh
Re: vr6 coolant leak
« Reply #1 on: 06 January 2011, 09:58 »
1 thing
water temp is normal
oil temp is normal
Offline javalin
« Reply #2 on: 06 January 2011, 14:50 »
where about was it leaking from?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline forsh
« Reply #3 on: 06 January 2011, 17:31 »
not to sure,i just see under the car on the snow is a nice orange slush
Offline javalin
« Reply #4 on: 06 January 2011, 19:18 »
left side, right side, front back?  Is it still leaking?
Offline dom
  • Back in a Mk4
« Reply #5 on: 06 January 2011, 22:25 »
Coolant should leave a crystal-like deposit where ever it leaks, have you had a good look around the engine bay for anything like that?
Offline Malz0r
  • Haters gunna hate.
« Reply #6 on: 07 January 2011, 10:35 »
Thermastat housing most common prob on the VR check first! it can be realy hard to spot it too! right at the front of the block bout half way down or so!
« Last Edit: 07 January 2011, 10:37 by Malz0r »
Offline forsh
« Reply #7 on: 08 January 2011, 09:04 »
its from the engine bay somewhere i think its the thermo housing to be honest ,but ill check it maybe later today and keep you posted on the progress
thanks all
1 tthing i remember doing about a year ago was take the pipes off the rad and drain all the sh!t out,the last owner mixed blue and pink coolant to make a nasty brown colour
ever since i changed back to pink g11 coolant its stayed pink
keep you posted
