Author Topic: Bloody B@stard Pot Holes!!  (Read 2776 times)
Offline dom
  • Back in a Mk4
« on: 04 January 2011, 22:04 »
So I was driving home earlier and due to a van coming the other way down a country lane at a stupid speed I hit a rather big pothole, or 2  :angry:
The rim doesn't appear to be damaged and the tracking is still ok, however when I pulled onto my drive something didn't sound right  :undecided:
There was a slight rattling/tapping noise coming from the back of the engine bay, my initial thought was that its the manifold heat shield. However when I revved the engine a little it got worse (as you would expect), but back box was rasping and popping a bit as if the exhaust was blowing somewhere.
I took the car for a drive around the block and sure enough it sounds like the manifold is blowing  :angry:
Is it possible that hitting the pothole has caused a crack in the manifold? Bearing in mind i'm on hotuning coilivers that are as solid as a rock, so any minor bump in the road is amplified massively anyway.
Offline boneybradley
  • Back in a Mk3...
Re: Bloody B@stard Pot Holes!!
« Reply #1 on: 04 January 2011, 22:12 »
a pot hole could easily kill a manifold! and there are not usually repairable (my passat one is cracked and I've tried all sorts to fix it!)
best get under the bonnet and have a check around! (hopefully it wont be serious?)
Offline dom
  • Back in a Mk4
« Reply #2 on: 04 January 2011, 22:15 »
Bugger, thats what I thought  :cry:
It'll have to wait til the weekend now, it's dark when i'm not at work through the week  :sad:
Offline Bellend
« Reply #3 on: 04 January 2011, 22:25 »
Grab a second hand manifold. U can't repair them. Weld them and they will expand when warm and the weld will fall out.
Where all my moneys went.
Offline Gash
« Reply #4 on: 04 January 2011, 23:15 »
best thing about owning an old car... bits cheap and everywere! ebay it!
Offline LowlifeDubber
« Reply #5 on: 05 January 2011, 08:17 »
Ive welded no end of cast manifolds and never had a problem :undecided: Give it a good prep gouging the crack out a bit better to get better penetration and use some 2.5 Ni-CL cast rods to fill and the same again to cap.
Never had any weld fall out yet :cool:
Cast rods are expensive  :undecided:
Offline Bellend
« Reply #6 on: 05 January 2011, 09:54 »
I stand corrected then. :cool:
Offline wakeskater
  • H20 PHW MK3 16V DAILY ,,,MK1 16V PROJECT,,
« Reply #7 on: 05 January 2011, 17:26 »
cumbria  and roads = POTHOLES  I KNOW..
Offline jonnypolish
  • t2871r needed :)
« Reply #8 on: 05 January 2011, 19:31 »
I feel for you man :( Hope it isn't too bad to fix!
 MK2 VR y0!
Offline Stirring Moose
« Reply #9 on: 05 January 2011, 19:54 »
Well I'm afraid I can't advise heading south to get away from them - we got some pretty good open cast mines in the roads down here in Devon too!   :sad:
S.M.
Love and hate, war and peace, joy and sadness... all just crap that happens between trackdays!
