Author Topic: 5x100 on 4x100?? with adaptors what et wheels?  (Read 2124 times)
Offline davies1644
« on: 04 January 2011, 01:31 »
Right looking at getting a set of wheels but will need an adaptor to make them fit wheels have a n offest of et43 wheel is 16" and 7J would these fit? as i need adaptors which are 20mm??
Offline les.tansey
  • VW Golf R32 MK5 & Mercedes-Benz E320 CDI Estate
Re: 5x100 on 4x100?? with adaptors what et wheels?
« Reply #1 on: 04 January 2011, 03:02 »
I might be wrong but I think that would make your cars wheels overall offset et23 which would mean your wheels would stick out quite far..
I think this is right, hope it helps,
Cheers, Les.
(As above) Golf MK3 & genuine BBS RX 16"wheels, now for sale separately - Just ask for details - Thanks, Les
Offline dom
  • Back in a Mk4
« Reply #2 on: 04 January 2011, 07:55 »
It depends on how low you are but et23 should be ok as long as your not stupidly low. As Les said the wheel will be closer to the arch, but 7J isn't very wide so should still give you clearance, what width tyres you running?
« Reply #3 on: 04 January 2011, 07:56 »
Don't think you can get 4x100 to 5x100  :undecided:
Offline dom
  • Back in a Mk4
« Reply #4 on: 04 January 2011, 08:01 »
 :grin: I completely missed that
Offline davies1644
« Reply #5 on: 04 January 2011, 10:07 »
you can get 4x100 to 5x100 fk do them and dont know bout tyres yet problem is im 120mm lows lol
« Reply #6 on: 04 January 2011, 10:27 »
I stand corrected, FK do make them.
ET23 is going to be mega tight running it that low, arch mods will be needed unless you find wheels that are a better offset.
Why do you want to run 5stud.
Only other option is to convert to 5stud.
Offline dom
  • Back in a Mk4
« Reply #7 on: 04 January 2011, 10:30 »
I reckon you'll need stretch and arch work to get them under the arches tbh :undecided:
Offline LowlifeDubber
« Reply #8 on: 04 January 2011, 11:10 »
Just change over to 5 stud.VR6 288mm up front and just change the stub axles on the back.Simples
« Reply #9 on: 04 January 2011, 11:27 »
He is running drums so will need to convert to discs.
