Author Topic: Bolster repair,'91 GTI 8V  (Read 5242 times)
Offline phope
« on: 02 January 2011, 12:15 »
Did a search but would like to confirm
This is my drivers seat, with a dodgy seat bolster where you can see the wear mark. I'd like to get a replacement bolster, and the guides look relatively easy, albeit fiddly
I doubt it, but do these replacement Recaro bolsters from Capital Seating have the same size/shape as the ordinary bolsters?
If not, where's a decent source of replacements?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270618059908&ssPageName=STRK:MEWAX:IT#ht_1460wt_726
Golf Mk8 R order cancelled...awaiting company car instead
Tiguan 1.5 Elegance for the wife & dogs
Skoda 1.5 SEL cheap lease special
Offline jocarl11
Re: Bolster repair,'91 GTI 8V
« Reply #1 on: 02 January 2011, 12:18 »
I'm not sure I can answer your question but that interior looks very clean!  :shocked:
Offline phope
« Reply #2 on: 02 January 2011, 12:22 »
Yup - sure is...managed to get a really well maintained car
Offline Steve_B
« Reply #3 on: 02 January 2011, 14:49 »
I'd say the best source would be another passenger seat, iirc you can swap all the different bits round to end up with a good drivers seat base.
Offline beechymonza
  • mad beech
« Reply #4 on: 02 January 2011, 16:08 »
I have just been doing a job in a settee repair shop,
And my bolsters are worn out worse than that,
But i found out that if you take your bolster foam out and take it 2 a local foam or settee manufacturers and ask them nicely they will knock you some up out of all there spare off cuts, :cool:
No guts No glory,
Offline tony_ack
« Reply #5 on: 02 January 2011, 23:59 »
+1
The passenger and driver's base foam and material are the same.
You'll need to swap the passenger foam material onto your driver's frame. Not too bad a job to be honest, it only gets tricky if you have to remove the material from the foam for whatever reason, which you shouldn't have to do.
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
Offline dubber36
« Reply #6 on: 03 January 2011, 09:20 »
+2
Try to get one from a 5 door as it won't leave you with the tilt handle hole in the wrong place.
Offline Ktuludays
« Reply #7 on: 03 January 2011, 14:15 »
i got mine from ebay. i just swapped the cloth over and job done.
i also reinforced the bolsters by taping over with bodge tape before covering wth cloth.
they are nice and firm now and less likely to crumble
<br /><br />What don\'t kill ya, makes you more strong!
Offline phope
« Reply #8 on: 03 January 2011, 16:04 »
Ok guys... Thanks
Any links to the ebay seller you used?
« Reply #9 on: 04 January 2011, 10:38 »
passenger 5 door best bet unless you dont care about tilt/backrest knobs bein in the wrong spot.  swaping base fabric is dead easy, backrest a bit more tricky. could just swap whole thing over and deal with knob issue or if 5 door one have a backrest that doesnt tilt at all. you can still make it tilt in an emergency if you release the 2 hooks at the bottom of the seat manually
