Author Topic: Forum search solves frozen pipe but ...  (Read 1542 times)
Offline dadrathers
« on: 31 December 2010, 17:40 »
In this cold weather my rear wash packed up and even after the thaw there was no water getting to the rear screen. I tried all the blockages etc. that I knew about but to no avail. However, a search of this brilliant forum told me to check adjacent to the rear light cluster – found the blown joint and sorted it – excellent.
BUT, I am now concerned that I have half a gallon of washer fluid sitting in a hidden well in the body ready to rust away.
Someone tell me that there is a drain hole in there that will allow the washer fluid to find its way to the outside of the car – please!
Offline Thom89
  • Looking for an "Icebreaker"
Re: Forum search solves frozen pipe but ...
« Reply #1 on: 31 December 2010, 17:52 »
"there is a drain hole in there that will allow the washer fluid to find its way to the outside of the car"
Hope this helps
Thom
Offline JC
  • Back in the North.
« Reply #2 on: 31 December 2010, 17:57 »
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 31 December 2010, 18:01 »
the drain hole is under the spare wheel (I think) so I would pull up the carpests and take the spare out and just give it a dry...
Just In case the hole is blocked..
For More Info Click To See;
Offline Thom89
« Reply #4 on: 31 December 2010, 18:02 »
Self diagnosis FTW, some people just cant see the wood for the tree's  :laugh:
Thom
Offline jocarl11
« Reply #5 on: 31 December 2010, 18:40 »
Same thing happened to my rear washer last week! The pipe came apart behind the rear light and my washer fluid kept dissapearing overnight, Lucky there is a drain hole under the spare wheel mate  :wink:
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #6 on: 31 December 2010, 18:45 »
Get some tubing from B&Q etc...
Attach to an empty washing up bottle and suck it out.
Offline jocarl11
« Reply #7 on: 31 December 2010, 18:50 »
As above but if it's not drained on its own then its probably just blocked up so give it a good clean.
Offline dadrathers
« Reply #8 on: 01 January 2011, 20:21 »
Thanks for the replies guys.
The point is that the join in the pipe is such that it can't leak into the spare wheel well - that would be easy to spot!! It leaks to the side of the rear wing down into the depths that are invisible. I hadn't noticed any fluid dripping out below the car  so that is why I was concerned that it was still in there. I will have a better look sometime but in the meantime will go with Thom since that is tha answer I was hoping for??????
Unless someone can confirm or otherwisee the presence of a drain.
