Golf mk5
Creamy substance on Oil filler cap
Topic: Creamy substance on Oil filler cap (Read 6148 times)
Snooze
31 December 2010, 11:34 »
I have noticed that there is a creamy substance on my oil filler cap when topping up the oil on my 2006 Mk5 Golf Gti. My head gasket isn't going is it? Its only done 58k and had a new cambelt at 54k. Please help!
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Rhyso
Global Moderator
Sir Postalot
Re: Creamy substance on Oil filler cap
31 December 2010, 11:42 »
Could be a bit of condensation. Do you do a lot of short journeys?
Take it for a cross country blast to clear out the cobwebs
Fire Up The Quattro
Snooze
31 December 2010, 13:17 »
I see. Yes I do do a lot of short journeys. Cheers Rhyso!
Saint Steve
31 December 2010, 15:39 »
Take rhyso's advice mate. Just check the engine cooling water expansion bottle for any signs of oil, if there's none, she just needs a good blast on the b roads for a few miles
When was it's last oil change and also what service regime is your car on? Long life or time and distance?
Gene Hunt.
31 December 2010, 20:20 »
This was covered a fair bit last winter & it does seem to be down to cold weather & short journeys,my old GTI did the same.
Candy White ED35.
Snooze
01 January 2011, 17:12 »
Just had a new Coolant expansion bottle and coolant is fresh and clean.
Last Oil change was March, and I check the oil level once a month. It was on Long life servicing until I purchased the car in March and now its on time and distance.
Cheers guys
TeddyKGB
Guest
Reply #6 on:
04 January 2011, 14:26 »
yep same here. As long as your filler cap doesn't look like this
nige_s
Guest
Reply #7 on:
04 January 2011, 14:47 »
Sounds like an Italian Tune Up is required.
Snooze
Reply #8 on:
04 January 2011, 19:07 »
Blimey that doesn't look healthy!
Gene Hunt.
Reply #9 on:
05 January 2011, 09:28 »
Quote from: Oops my bad on 04 January 2011, 14:26
........Rover k series ??.
Candy White ED35.
Golf mk5
