Author Topic: problem number 3  (Read 1924 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
problem number 3
« on: 17 February 2005, 19:12 »
ok i just been outside to go for petrol
and i started it and its chuggin exhaust is poppin again
so i drove down road a bit n it chugged then went normal for a second then chugged again
what could this be as I am not goin to put another head on if thats knackered again
plus i have not been drivin it hard since it was fixed :cry:
Offline Mr Blue
Re: problem number 3
« Reply #1 on: 17 February 2005, 19:24 »
i remember you telling me there is no exhaust manifold gasket? that true?
Offline VR6_ROB
« Reply #2 on: 17 February 2005, 19:32 »
they is one on i found out he put old one back on
Offline carrie
  • i can see into your soul and its not good
« Reply #3 on: 17 February 2005, 19:36 »
when the gasket went did it overheat?. if so did you check the head wasnt warped?
SAY YOU LOVE SATIN?, NO SATAN, ITS SATAN
Offline VR6_ROB
« Reply #4 on: 17 February 2005, 19:39 »
never overheated just burnt all the oil away I am givin up if its the head again seems like im wastin my time
ill just save up for a vr6 lump but then again i want to go to newark in april
Offline VR6_ROB
« Reply #5 on: 17 February 2005, 20:32 »
Right I been back outside n it started up str8 away no problems was'nt chuggin no more all the power is back?
any1 got any clues wot it cud be damp or out dont like panicin thought i was gonna hav to fork out
for another head or summat
Offline VR6_ROB
« Reply #6 on: 20 February 2005, 22:05 »
my car did the chuggin thing again this mornin so i carried on drivin n after a minute or so it sorted itself out
could it be fuel i cant show any1 what it is because its fixed by the time i get to a garage
Offline Dizzie
  • Make friends with your fast
« Reply #7 on: 20 February 2005, 23:18 »
is it firing on all 4?
have you changed the dizzy and the roter arm? (cheap to do)
Put a plug in each lead and then earth the plug. that'll verify the spark is working and the leads aren't faulty. careful not to shock yourself though!
when was the last time you changed the fuel filter or put some injector cleaner through? could be a block, but after a while it blows through. then blocks again when it's not running for a long time.
just some ideas.
Mk4 Golf 150PD
Offline VR6_ROB
« Reply #8 on: 21 February 2005, 18:58 »
ive never changed the dizzy or rotor arm
its got new plugs n leads few weeks ago
never changed fuel filter
so i will give them a bash
