Author Topic: the famous "red lead" connector  (Read 3883 times)
jamrock
« on: 27 December 2010, 20:43 »
i am trying to get my 16v running right in this cold cold weather. i have read the guide on how to set it up to prevent it from stalling. i have check near my coil and i dont seem to have the "Red Lead". i have a U shaped jack plug which connects to the coil.
does the Red lead give the ISV power?? i do have the isv control box which connects to the fuse box.
Offline mattkh
Re: the famous "red lead" connector
« Reply #1 on: 27 December 2010, 22:05 »
Hi
What is wrong with it ?
Offline Adam
Down Hill From Here.
jamrock
« Reply #3 on: 27 December 2010, 22:48 »
Hi
the car takes about 5 to 10 mins to warm up. cant just jump in and drive.. i have to hold the revs above 1000 so else it will stall.
http://www.edition38.com/forums/index.php?showtopic=174696&pid=3331286&st=0&#entry3331286
ive read this guide, i just cant find the red connector he talks about. i dont seem to have one.
http://www.golfgtiforum.co.uk/index.php?topic=22031.0
the red connector in fig 1
« Last Edit: 27 December 2010, 22:52 by jamrock »
Offline mattkh
« Reply #4 on: 28 December 2010, 20:31 »
Hi
Can you see the terminal numbers on the coil ? They are 1 40 15.
The U-shaped connector to terminal 1, what color wires are on it ?
jamrock
« Reply #5 on: 28 December 2010, 21:21 »
i think from memory, its a red/black and a green wire. i will try have a look at the coil tomorrow.
Offline mattkh
« Reply #6 on: 29 December 2010, 22:52 »
Hi
Well done.
The green is for the tci-h unit.
The red/black is for the rev counter.
If you only have 1 red/black to terminal 1, then the previous owner has bypassed the isv control unit.
jamrock
« Reply #7 on: 29 December 2010, 23:54 »
NOOOOO!!!
what do i do to get the isv running then?? i am getting power to the control box does it mean i am getting power to the isv itself??
oh and what is tci-h unit??
thanks
« Reply #8 on: 30 December 2010, 09:46 »
the isv control unit gets power from the fusebox, does the isv buzz?  was this a factory 16v or an engien conversion?
jamrock
« Reply #9 on: 31 December 2010, 00:16 »
the car was converted by the pevious owner, the wiring was a a right bodge job :angry:
when i turn the key i hear a bussing noise but i have a feeling that its the fuel pump priming maybe?? when i put 12v to the isv it does click
 whats the part number for the ISV?? there seem to be new ones for sale on the bay, i have brought a used one but that seems to be f**ked to
http://cgi.ebay.co.uk/VW-Corrado-2-0-Idle-Control-Valve-037906457C-NEW-/230566490828?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35aed572cc
this seller says to give the part number on the ISV so they can send out the correct one for the car.
« Last Edit: 31 December 2010, 00:22 by jamrock »
