Author Topic: Anyone help.Fuse 14 blowing  (Read 4228 times)
Offline chrisj
« on: 23 December 2010, 10:26 »
Hoping someone can help.My girlfriends 03 plate gt tdi keeps blowing fuse 14. If i replace it the interior lights come back but if you try to then lock the car using the key it blows(well i assume its that as that's all i do after shutting the door).Also the central locking has stopped working off the fob and key.Does anyone know if there's something simple i'm missing.Thanks
R Tech stage 1 AUM, Pipercross panel filter, forge 007p, Santa Monica's,Lowered 35mm Jamex Shocks and springs, Milltek Exhaust, mk5 rear wiper
Offline richw911
Re: Anyone help.Fuse 14 blowing
« Reply #1 on: 23 December 2010, 10:29 »
Check the boot light it can sometimes short on the body.  :smiley:
Could be a faulty door module  :undecided:
and see this
http://www.golfgtiforum.co.uk/index.php?topic=77197.0  :smiley:
« Last Edit: 23 December 2010, 10:31 by richw911 »
Offline chrisj
« Reply #2 on: 23 December 2010, 10:30 »
When you say check it what do i check for? :embarassed:
Offline richw911
« Reply #3 on: 23 December 2010, 10:32 »
Make sure the metal part on the back of the unit is not touching the body.
Offline chrisj
« Reply #4 on: 23 December 2010, 10:33 »
Ah right i understand now. I'll check it out. Thanks
Offline chrisj
« Reply #5 on: 23 December 2010, 11:00 »
The boot light isn't even connected.The connector thats there spare won't even fit onto the boot light as if it's wrong. I took the light out and tried again but as soon as i turn the key in the lock it blows . Anymore ideas??
Offline Rhyso
« Reply #6 on: 23 December 2010, 11:09 »
Silly question but you are replacing it with a 10amp and not something lower?  :undecided:
Sounds like you've got a short somewhere  :undecided:
Offline richw911
« Reply #7 on: 23 December 2010, 11:10 »
Could take the door panel off and unplug the door module see if its that  :undecided:
Offline chrisj
« Reply #8 on: 23 December 2010, 11:13 »
Yes Rhys, replacing it with a 10 amp. Just glad it's not my car for a change.
Offline chrisj
« Reply #9 on: 23 December 2010, 11:22 »
Thanks, I'll try having a look this afternoon when i get a bit of time. Just hope she can find out the problem
