Author Topic: double din  (Read 2578 times)
Offline seanieb
double din
« on: 23 December 2010, 06:25 »
hi all, just need to ask will a double din headunit go straight in my mk4 golf or do i need to buy a cage or something?
Offline chrisj
Re: double din
« Reply #1 on: 23 December 2010, 06:50 »
Mine came with a cage when i bought it, so you would need a cage to hold it securely
R Tech stage 1 AUM, Pipercross panel filter, forge 007p, Santa Monica's,Lowered 35mm Jamex Shocks and springs, Milltek Exhaust, mk5 rear wiper
Offline hainesz
  • MK4 GTi 1.8T 20v AGU
...Burn Rubber...Not Your Clutch...
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
Re: double din
« Reply #3 on: 17 January 2011, 17:51 »
Quite rightly put from previous post. Some double dins do come with there own cages..but they never always fit correctly as they sit a bit too tall for the aperture provided in the golfs. so you end up havin to get the double din fascia kit anyways.
You can however try and retrofit the cages that come with the double din radios...of course you may still require a double din fasica surround to close up the gap around it perhaps. or sometimes you can get away with that too.
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
