Author Topic: Fuel pump relay mk2 1.8v pb digifant  (Read 5253 times)
Offline scooter perv
« on: 22 December 2010, 10:21 »
Needed a fuel pump relay and went to a local parts suppier and he supplied me with a similar relay that fits ok and seems to have the same diagram stampped on it but its marked 428. Now my cars dies and refuses to start and Ive googled the part number 1J0 906 381B but the relay seems to be for a 1998 beetle etc and not even a pump relay. Will this be a problem do ya think cos its doing me nut in now..not sure if thats the reason for the car not starting cos I have other issuses with it :sad:
Offline weazgti
Re: Fuel pump relay mk2 1.8v pb digifant
« Reply #1 on: 22 December 2010, 10:34 »
Have a search on here, im sure theres a method to bridge the pins where the relay goes to rule out whether its a relay or not.
« Reply #2 on: 22 December 2010, 10:37 »
cheers mate,,ive killed the old relay so not an option at the moment just wanted to check that this relay was ok as a fp relay. Google tells me is a ecm relay for a mk5 golf..think the geezer who sold me it is a bit of a chancer
« Reply #3 on: 22 December 2010, 12:01 »
generally fp relay are 67, 80 or 167, can be found on mk2 digi/16v and any petrol mk3.
as above, get a jumper wire and put it between the 2 large pins on the relay socket, fuel pump should fire up and run constant. if car still doesnt start the problem is elsewhere
