Author Topic: 1st vr6 conversion....  (Read 10990 times)
Offline Diamond Hell
  • Opinions я Us
Re: 1st vr6 conversion....
« Reply #10 on: 20 December 2010, 22:27 »
020 02a ?? sorry wats the diff ??
Gearboxes - one is cable-cange, t'other is the more common and rubbish rod-change.
If you're looking for 'lightning fast' then do you want a big heap of BHP or are you OK to lose a lot of weight?
A cat can be skinned in more than one way.  :grin:
VR6 or ABF will be easier than a 1.8T
Offline AudiA8Quattro
« Reply #11 on: 21 December 2010, 17:03 »
1.8T will be front heavy like the vr6 in a mk2.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #12 on: 21 December 2010, 17:17 »
is the 1.8t that heavy then mate ??
Offline bally
« Reply #13 on: 21 December 2010, 17:51 »
to be honest im way confused now.
if i want lightening quick what is the best way to go? say 300bhp?
i will be stripping the car right down so weight wont be an issue.
and what sort of money will i be looking at to do this if I already have a solid mk2 (i dont as yet but will have!)
cheers
carl
Offline lemski
  • 16v
« Reply #14 on: 21 December 2010, 18:21 »
1.8t but then its more work. So really depends how much work your willing to do and also how big the budget is.
Offline bally
« Reply #15 on: 21 December 2010, 18:30 »
cheers for the reply,
im looking at spending around 1000 on the mk2, then prob around 3-4k on the conversion and all parts. hopefully i will be able to do it all myself so that should keep costs down.
Offline lemski
  • 16v
« Reply #16 on: 21 December 2010, 18:35 »
Choose which ever but get a full car so you've got everything you need. Also research what fuelpump and that you need. I should say a 2litre mk3 16valve on bike carbs, and engine concentrated on and that'll be enough. Lsd for good measures though. Turbo is just another thing to go wrong.
Liam
Offline bally
« Reply #17 on: 21 December 2010, 18:39 »
Liam
sounds good, and do you think i could do that on my budget?
Offline lemski
  • 16v
« Reply #18 on: 21 December 2010, 18:47 »
I managed to do a 1.8 16valve on 400 including buying the other car. Its possible if you look about for a cheap donner
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #19 on: 21 December 2010, 19:02 »
what bhp will a 2l 16v run if on bike carbs ??
