Author Topic: vw bora clutch issue  (Read 1937 times)
Offline gti_copey
  • need...... more.......power!!!
« on: 20 December 2010, 11:01 »
hiya just after some helpful advice ive got a bora tdi pd130 6 speed and the issue is.... its slipping  :cry:
just wondered if theres any alterations i can use like the 20v's run the vr6/g60 arrangement..
is there something else i could possibly use??
thanks in advance  :smiley:
GolfGTI.co.uk & R-Tech Summer RR day/Meet Coming Soon - Any excuses and you will be barred
Offline Rhyso
Re: vw bora clutch issue
« Reply #1 on: 20 December 2010, 19:43 »
Sadly not
If you want to upgrade you either get a single mass flywheel and suitable clutch and some extra strong denture glue or you bite the bullet and get a Sachs Organic clutch which is good enough for around 400lbs ft torque
It isn't cheap.  I think the clutch kit alone is now well north of £550!!  :cry: :cry:
Offline flamotronic
« Reply #2 on: 20 December 2010, 22:57 »
Personally, if you're not remapping your engine to a ridiculous amount f power and torque you're better off getting the same replacement parts. Whilst tackling the clutch you may as well replace the flywheel too as there's no point dismantling the clutch/flywheel assembly again when the flywheel does fobber up.
Whatever you do, don't get the single mass flywheel! You'll regret it on a TDI. Period!
PQ34 Wolfsburg Type 1J Turbo-direct Injection Pumpe Duse 115
A work-horse of a vehicle; this and that going wrong, but it's still a Dub, 'aint it?!
Offline gti_copey
« Reply #3 on: 21 December 2010, 10:31 »
i was hoping someone wouldnt say that :(
oh well looks like ill be forking out £1200 that includes the flywheel aswell..... possibility i might get it a little cheaper through my good friends at jabba... im not going silly power on the car want it to be around 210-220bhp mark so want a decent clutch anyway :)
thanks for the replies thoe guys much appreciated!! :)
Offline GOLF_STU
  • THE_GIT
« Reply #4 on: 24 December 2010, 21:05 »
ha ha ha you will never beat my mk4  :tongue: that'l teach ya for stripping your golf.......the clutch was fine in that  :wink: :grin:
V TEC KICKED IN Y'ALL!!!
