Author Topic: ECU  (Read 1145 times)
Offline Tazzy
ECU
« on: 19 December 2010, 12:25 »
1.8 20v non turbo
is it right, that when lifting the bonnet, i can see the ecu through the grille on the scuttle panel (as its located in the centre under the windscreen)
thanks
also, to add, anybody noticed how wimpish the rear washer jet is, the jet only partly sprays up a 3rd way up the window, which is pointless as i want it to clean all the window thanks!  :rolleyes:
« Last Edit: 19 December 2010, 15:42 by Tazzy »
If It Comes Off, Modify It!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: ECU
« Reply #1 on: 19 December 2010, 12:32 »
yes to the ECU and give the nozzle a clean
Offline Mr_Orange
Re: ECU
« Reply #2 on: 19 December 2010, 12:40 »
Yep, take the bolt cover off and give that nozzle a prod around with a drawing pin  :wink:
Also perhaps check the washer fluid isn't leaking inside the boot or headlining...  :sick:
Build thread clicky
Offline Tazzy
Re: ECU
« Reply #3 on: 19 December 2010, 12:57 »
hmmm, as you mention it, my boot panel is off at the moment due to the locking mechanism playing up, i did noticed a blue stain on the under side
is there meant to be a cover for the ecu? if not, ill make one, if so, bonus! but wheres mine?  :sad:
this is what my electrical problems were, a wet ecu, water had got into it, all sorted now though, but i dont want a repeat performance thanks!
Offline mattkh
Re: ECU
« Reply #4 on: 19 December 2010, 14:09 »
Hi
I need a favour. Before you put back the boot panel, please take a general picture of whats in that area and put it up here. Cheers.
Offline richw911
Re: ECU
« Reply #5 on: 19 December 2010, 15:18 »
The blue stain says to me its leaking or has been at some point  :wink:
http://www.golfgtiforum.co.uk/index.php?topic=150271.0
