Author Topic: 90 Spec Side Skirts  (Read 1858 times)
Offline Kent
90 Spec Side Skirts
« on: 16 December 2010, 14:08 »
Hi all,
I have 5 door small bumper with the vynal sticker side skirts. Does any one know if the 90 spec skirts will fit?
If they do does anyone one know where I can get them?
Re: 90 Spec Side Skirts
« Reply #1 on: 16 December 2010, 14:50 »
they will fit any mk2, but you also need to change the arches and the rubbing strips. dont forget to buy a fitting kit. gsf used to sell the arches and skirts, big boys toys did too but i think 1 side skirt is discontinued now. both places iirc did the fitting kits as well.  or look on ebay for 2nd hand.  vw still stock the fitting kits but again 1 side skit deleted. think they still sell all 4 arches tho
Offline Kent
« Reply #2 on: 16 December 2010, 15:06 »
Cheers for the info.
Ive just taken off the arch trim and side strips and smothed it will this caurse any problems?
« Reply #3 on: 16 December 2010, 15:17 »
you wont get the skirts on without the arches, find a piccy of a 90spec gti and it'll be obvious why!  side strips you dont have to fit though, can just snap the front wing bit off. leaves a slight gap though which isnt that noticable, tho a bit of carefull plastic welding and some smoothing would make it less visible
Offline Kent
« Reply #4 on: 16 December 2010, 15:36 »
Cheers,
I understand what you mean, I wanted to keep the arches off to keep its all smooth. I can see that this is not going tobe an option for me with original VAG parts.
Would there be an aftermarket side skirt that would do the job?
Cheers for your help
« Reply #5 on: 17 December 2010, 08:23 »
i cant think of any off hand which dont also come with an arch kit, you can get vinyl stickers for the sills which was std on the pre-90 GTI?
