Author Topic: Not pi**ed off now  (Read 2527 times)
Offline ash1.8T
Not pi**ed off now
« on: 15 December 2010, 20:17 »
Hi guys
A few months ago my car started to make a knocking noise   which turned out to be the timing chain tensioner saying bye bye. I got the timing chain tensioner changed along with a new chain and cambelt + water pump.
This has stopped the knocking noise woo  but I've had the car back a month now and it's not running rite it keeps on jerking while acceleration and won't start first time. I did abit of reading and fort the MAF was the problem but I've jus changed it and it's not any better
Need help please
Also when I first got the car I had a health check done by Vw and it claque that my diverter valve was on it's way out. Could that cause the jerking?
« Last Edit: 23 December 2010, 08:18 by ash1.8T »
Offline Chris36
Re: Starting to get pi**ed off now
« Reply #1 on: 15 December 2010, 22:04 »
Hi guys
is the timing spot on? could it be a tooth out??
Need help please
Offline AaronGS
« Reply #2 on: 15 December 2010, 22:25 »
Where are you? ideally someone nearby could scan it and give you and answer. Otherwise its guess work really.
Offline ash1.8T
« Reply #3 on: 16 December 2010, 03:57 »
I live in Crawley. Scaning it would make it easer lol giv a clearer idea of what is wrong
Offline vwblackmk4gti
« Reply #4 on: 16 December 2010, 09:19 »
what engine is it fella,
I had this problem with my 1.8 20v n/a engine, after scanning the car with vag found out it was the throttle body. If you cant get to scan your car. test the resistance with a multimeter on the throttle body should get a good indication then..
Offline ash1.8T
« Reply #5 on: 16 December 2010, 15:27 »
Oh yh forgot to put that up it's a 1.8t aum gona try to get it scanned. I drove it to a from work today and it felt alot better only jerked a once or twice as apposed to all the time. Also only seems to jerk when it's warm
Offline Khare
  • The bear that khares
« Reply #6 on: 16 December 2010, 15:30 »
As you've had the timing stuff worked with I'd say it's connected with it, so my guess would be they've timed it up wrong.
Offline 2001gti4
« Reply #7 on: 16 December 2010, 15:46 »
+1
I'd agree with this, Mr Clutch put mine back together one tooth out and it didn't run right, plus went into limp mode due to overboost now and again.
My Golf is dead but at least I have this....
nige_s
« Reply #8 on: 16 December 2010, 16:01 »
Sounds like a crank position sensor to me.
Offline simon20vt
« Reply #9 on: 16 December 2010, 18:46 »
Maybe starting first time could be a seperate problem? if so maybe the pcv system?
