Author Topic: richandhazel's Golf VR6  (Read 103166 times)
Offline The Doc
  • E63s Estate - Vito Sport
Re: richandhazel's Golf VR6
« Reply #40 on: 26 December 2010, 17:26 »
Great deal at that money :-)
Offline richandhazel
« Reply #41 on: 29 December 2010, 21:54 »
Weather now warmer so progressed today :smiley:
Decided I needed better access so removed the bumper, trim and front valance with radiator:-
« Reply #42 on: 29 December 2010, 21:57 »
The transfer tube from the water pump is really in a bit of a mess:-
This is how the new one looks at the water pump end:-
............should improve things :undecided:
« Last Edit: 29 December 2010, 22:11 by richandhazel »
« Reply #43 on: 29 December 2010, 22:01 »
Blocks not much better:-
« Reply #44 on: 29 December 2010, 22:04 »
Looking through that aperture in the last picture I can see that the vanes on the water pump are missing/broken so a new water pump is now on order.
This cooling system has really been through the mill.....I will be lucky if the head and gasket are OK :undecided:
« Last Edit: 29 December 2010, 22:22 by richandhazel »
« Reply #45 on: 29 December 2010, 22:20 »
Thanks, I hope so.......really looking forward to driving this :smiley:
« Reply #46 on: 29 December 2010, 23:10 »
Water pump order now cancelled. Having read on other forums about the quality of ECP water pumps have decided to order OEM from VAG, same price and might just last more than 3 months. Anyone here had the same problem with ECP water pumps? There appear to be two available, around £10 difference in price so I'm guessing the OEM one is the more expensive but cheaper from VAG?
« Last Edit: 29 December 2010, 23:33 by richandhazel »
Offline SoundillusioN
« Reply #47 on: 30 December 2010, 02:26 »
Hey Rich,  nice to see you getting stuck into this so quickly... Must get back on to mine now Christmas has past and the freeze appears to have left us.....
Blimey that does look a bit rough... What's been used to try and seal it on the old pipework? Looks like lard!
Is there any damage to the block or is that just crud we can see in your pics.
Keep at it mate, shouldn't be long before you'll be grunting up and down the carriageways.  :smiley:
Shaun
Offline AudiA8Quattro
« Reply #48 on: 30 December 2010, 09:40 »
I did get a bad water pump for the Audi 100 from ECP once.
I couldn't say if i was just unlucky though, most bits from them have been pretty good.
« Reply #49 on: 30 December 2010, 10:51 »
Just to add, your coolant system looks well messy mate  :grin:
