Author Topic: girl in need of help!!!!  (Read 3103 times)
Offline theravinfairyxx
« on: 14 December 2010, 14:11 »
hey guys. so I have attempted by myself to wire in a sub with built in amp in my mk4 1.8t and everytime I start the car the sub seems to get a power surge and kicks out one thumping noise. I wired the sub to the ignition and the amp control to the anntenae and used rcd fir the speakers. it didn't do this in my last car. please help cos I'm sure it's not normal. thanks guys!!!
Offline N900 MJT
Re: girl in need of help!!!!
« Reply #1 on: 14 December 2010, 14:22 »
Are you running a live wire straight from the battery?
« Reply #2 on: 14 December 2010, 14:39 »
no I don't think so just ignition
Offline N900 MJT
« Reply #3 on: 14 December 2010, 15:01 »
I would suggest wiring it properly (not saying what you have done is wrong) - Live wire straight from the battery, then the remote from the headunit to the sub to tell it to turn on.
Also make sure that the earth wire is touching bare metal not a painted surface - this is one of the most important things that you need in the system
Also make sure the fuse is the right amount to work with your wiring
Offline Len
« Reply #4 on: 14 December 2010, 15:41 »
Sounds like a poor earth to me.
www.sas.org.uk
www.the-ace.org.uk
Offline AndyMk3
« Reply #5 on: 15 December 2010, 18:10 »
Where are you based? could a fellow dubber help?
« Reply #6 on: 17 December 2010, 15:19 »
I live in taunton. it's earthed properly.
Offline VR6_Wherry
« Reply #7 on: 18 December 2010, 16:20 »
if it's earthed properly i would wire it up the way P884 POT has described.
Offline benny1234black
« Reply #8 on: 21 December 2010, 20:29 »
+1 make sure its a decent earth as that is a the cause of so many problems when its a rubbish one
Not got my next golf yet waiting for the right one!
« Reply #9 on: 21 December 2010, 20:30 »
Yes make sure it is a decent bit of bare metal that is not painted.
