Author Topic: De-Cat By itself?  (Read 1763 times)
Offline +49
De-Cat By itself?
« on: 13 December 2010, 10:25 »
Hi guys quick question.
Was wondering if I could could simple fit a £50 Decat to my 1.8t AGU without having an exhaust system?Will i still get some benifit/worth to the mod?Don't fancy modding the rear bumper and having the expense of having the aftermarket exhaust system.Will it increase noise at all with the standard exhaust system and de-cat fitted also?
Thanks!
Re: De-Cat By itself?
« Reply #1 on: 13 December 2010, 10:53 »
Not really worth fitting on its own plus you will need the cat for the mot.
Offline +49
« Reply #2 on: 13 December 2010, 12:38 »
Humm, ok dude just figured its a fairly cheap mod thats supposed to add BHP and improve  economy.
Thanks!
Offline andc1
« Reply #3 on: 13 December 2010, 15:21 »
yep just done it mate and works a treat! better top end and more pull i feel, just dont get pulled and keep ya cat for mot!!!
Offline houston
« Reply #4 on: 13 December 2010, 15:57 »
wont get the benefits uness you get the lambda sensor values altered, itll prob throw a fault code.
Offline andc1
« Reply #5 on: 13 December 2010, 16:03 »
you'll be fine on a agu, make sure you put the sensor on tho!!!!  :grin:
jamie16v
« Reply #6 on: 13 December 2010, 17:55 »
it`s deffo worth doing and makes quite a difference, even with a standard exhaust.
