Author Topic: Anyone else had trouble fitting 4 Motion Valances? Milltek fitting issues.  (Read 6850 times)
Offline teccers
Ok, so here's the story. I recently bought a Milltek Twin Jet Cat-Back system for my Golf 20vT along with 4 Motion valances for the front and rear (bought from main dealer), the parts in total cost me £445 (£338 for Milltek and £107 for valances). So, I booked the car in at AVW (VW Specialists) to get the exhaust and valances fitted. Turns out they've had great difficulty fitting the valances and they don't even line up properly, also the towing eye at the back doesn't fit in the cut out on the rear valance, does the towing eye need to be taken off? Also, I'm not happy how the Milltek fits either, is it a bad fitting exhaust? It looks like it's on the piss and when braking the exhaust hits against the body causing a shudder type noise. When it came to paying they told me it took 8 hours to fit the exhaust and valances but they'd only charge me for 5, so the total was £284.29 (which I thought was a bit steep). The exhaust is only a cat-back, so should this of taken 8 hours to complete? Are they having me on? Has anyone else had any difficulty fitting the 4 Motion valances to their Golfs? Pics..
Front valance doesn't line up..
Exhaust doesn't look too bad in this one but once you go over a bump it goes out of place.
Offline nadlad
  • Building Surveyor MRICS
did u get a free tub of vaseline with that
<<<Big Build Thread>>>
Offline Adam
When I had my front 4motion valance it was a bugger to fit right. Never did get it to fit right actually. The Anni one when on fine though.
Down Hill From Here.
Offline nadlad
mine was a thingy too i hd to wedge in plastic into the clip to stop them from popping out and linign up, in terms fo fitting the exchaust am sure u need to angle grind a tab off the rear fo the car in order for it to fit, the towing hook doesnt line up either u can either blank it off or just push your valence under it.
otherwise mate am sorry to say but u got well and truely scammed for payign 284 quid  for fitting coz most places if u buy the exhuas they fit it free, well they do at r tech. i
Offline nadlad
if ure exhaust pipes are sliding and not sitting central to the cut out u just need to tighten a small clamp or some thing to the back of the box to stop it from slidign thats what i did
still 284 quid f**kign hell mate
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
I had to put a jubilee clip on the hanger behind the rear box to stop it moving around on my Blueflame
Offline navmk4gti
i dont get why you paid if nothing was fitted propley..  :huh:
i would of told them i give you £5 ..cause thats the quality of work you have done so do it right or f**** o**  :grin:
Offline tech1889
  • Mk2 GTI FTW !!
I'm having trouble fitting the valance as well it lines up but can't get the last tab each side into place am thinking of removing bumper and fitting the valance separately.. My exhaust is also knocking the chassis at the tip.. Hmm I fitted my self so looks like I still saved £280..
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
my mate charged me a ton to do mine which I thought was good. tech you're best off taking the bumper off and doing the valance, try and do it somewhere warm too
Offline nadlad
thats what i did
