Author Topic: Rear Camber, toe... Is it adjustable?  (Read 2492 times)
Offline berni29
« on: 09 December 2010, 07:53 »
Hi There
Apart from playing with the rear axle hangers (they have some possible adjustment when loose) is there any adjustment on the rear of a MK2 Golf GTI?
Many tks... Berni
Offline Ben Lessani
Re: Rear Camber, toe... Is it adjustable?
« Reply #1 on: 09 December 2010, 07:57 »
The only way its adjustable is via sub axle camber shims. The angle at which you fit them will dictate camber/toe.
Bear in mind that the rear beam is on a radius, so if your car is lowered, then you have to set the shims about 3 degrees out from the recommended settings to prevent toe-in.
Offline berni29
« Reply #2 on: 09 December 2010, 08:31 »
Hi Ben
Very interesting thanks. It is lowered by 40mm or so. It had a PI lowering kit with standard rate springs and gas dampers. Good suspension actually.
I have a trackrite so will check the rear toe. I have just bought a camber gauge so once the kids give it to me for christmas I will use that. It does look like it has a spot too much -ve at the back. I can live with that tho. The toe I want right. You do not know what the spec is do you? I can probably search for it although I have not stubled across the figures yet.......
All the best
Berni
Offline Ben Lessani
« Reply #3 on: 09 December 2010, 08:34 »
Here's the reports from my 4 wheel alignments, should give a reasonable impression of the factory figures. The rears have quite a lot of rear camber anyway, makes it a bit tram-line-y but doesn't effect the overall drive or tyre wear.
