Author Topic: Car revving when pulling up to stop  (Read 4644 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Car revving when pulling up to stop
« Reply #10 on: 04 December 2010, 19:16 »
Air leak after the maf, maybe tip, brake check valve or PCV, or even naffed TB. Just unplugg the maf and see how see runs, you will have low generic load of only 5.5ms which is half the cars current performance but it should set the idle into a generic mod, and it it sorts this issues out its then its the maf or air leak.
 01455 617233
Offline Jayman79
« Reply #11 on: 04 December 2010, 22:49 »
I've got a GT TDi and mine when I first start up, after a few minutes of driving and when I come to a stop, mine always goes from 0.7/8 to 1.1/2 for a minute or so but then remains consistant once she warms up a litlle?  Does it ease off or is it constant?
Optimists think the glass is half full. Pessimists think the glass is half empty. Realists know that someone will have to wash the glass.
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #12 on: 05 December 2010, 10:20 »
Nick, it doesnt seem to be a constant problem. will see how it goes over next few days.
Wez - is that all you do to re-align TB?
Offline navmk4gti
« Reply #13 on: 05 December 2010, 19:16 »
im gettin the same problem on my agu  but once the car is warm its fine .. but if i go on a really long journey and im pulling up to stop the revs stick at like 1500 rpm ..then i jus rev it a little and it settles.. happens rarely tho   :undecided:
Offline Dan_GTI
  • GTi addict formally known as yoof
« Reply #14 on: 05 December 2010, 20:25 »
could be wrong but i've heard of faults with the clutch switch, if its faulty it'll send incorrect values back from the sender telling the engine to idle.... this was on a passat though.
MK4 H&R 50MM SPRINGS FOR SALE £100 BRAND NEW
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 05 December 2010, 21:00 »
AGU doesn't have such things lol
Offline Dan_GTI
« Reply #16 on: 05 December 2010, 21:14 »
Sorry... im an AUM man  :grin:
Offline Grand Master Patch
« Reply #17 on: 06 December 2010, 07:44 »
nah "the turn the key to put the dash lights on with the door open" trick :wink:
LOLOLOLOLOLOLOLOLOLOLOL :grin:
Don't forget to stand on one leg and pat your head :grin:
Offline topher
  • Administrator
  • fully functioning
« Reply #18 on: 06 December 2010, 14:15 »
Get some logs done dude, block 098.. i seem to remember your TB causing issues before, perhaps it's finally given up the ghost.
Offline Hulmie
« Reply #19 on: 06 December 2010, 17:08 »
yeh was having problems before with the TB, think you reset it as it was only open 50% on full throttle.
I dont have Vagcom or a laptop. maybe santa will be nice to me.lol
