Author Topic: Car revving when pulling up to stop  (Read 4632 times)
Offline Hulmie
  • White MK4 1.8T AGU K03s
« on: 04 December 2010, 10:34 »
Car is currently dropping off and on revs when coming to a standstill at junctions/lights etc.
not sure if this is just down to the weather were having. Anyone have any idea's what may be at fault?
Offline richw911
Re: Car revving when pulling up to stop
« Reply #1 on: 04 December 2010, 10:37 »
TB clean/fault?  :undecided:
Offline Hulmie
« Reply #2 on: 04 December 2010, 10:51 »
TB is fairly clean mate, no management light but ya never know with AGU's.
will see how it is, may just be down to the weather and car needing a good run
Offline richw911
« Reply #3 on: 04 December 2010, 11:04 »
Could be the MAF or a boost leak  :undecided:
Offline Hulmie
« Reply #4 on: 04 December 2010, 11:36 »
Maf was new earlier in the year and was at R-tech just over a month ago and only leak found during the smoke test was repaired.
it'll just have to wait until weather is better so i can get somewhere to get it scanned.
Offline vwprime
« Reply #5 on: 04 December 2010, 11:55 »
Exatly what i had and after cleaing the MAF it was all good agine. Has the Golf stalled yet Paul?
TRANSFORM, & ROLL OUT!
Offline Hulmie
« Reply #6 on: 04 December 2010, 12:25 »
nah not stalled yet mate, just revs between 200 - 1000rpm when coming to a standstill
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 04 December 2010, 14:20 »
you tried readapting the throttle body?
Mine was doing this after Nick had played with my map in the summer, was fine after I readapted it
Offline Hulmie
« Reply #8 on: 04 December 2010, 19:00 »
Wez, do you mean just unbolt the TB and then bolt it back on and let it adapt itself
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 04 December 2010, 19:06 »
nah "the turn the key to put the dash lights on with the door open" trick :wink:
