Author Topic: Can I use a 16V Block on a 8V?  (Read 1781 times)
Offline juicey
« on: 04 December 2010, 09:18 »
Ive got my hands on a complete 16V engine and was wondering if I can use the block as a replacement for my 8V? I know there are a couple of things that are different like the engine breather but Im thinking I can simply use the parts from my 8V, as an example the 16V has a engine breather on the side of the block and I thought I could use the blanking plate from my 8v engine for that, I was looking at rebuilding the bottom end of the 16V during the winter ready for a swap into my 8V in the spring.
Any advise would be appriciated :)
Re: Can I use a 16V Block on a 8V?
« Reply #1 on: 04 December 2010, 09:20 »
Don't think so.
Better to stick with the 8v block.
Offline apie2004
« Reply #2 on: 05 December 2010, 18:04 »
Swap it all?
Offline juicey
« Reply #3 on: 05 December 2010, 20:16 »
No no no, dont wana do that as I want to keep it origional as far as i can, swapping to a 16v would also mean changing the ecu and the wiring and Im only looking for something to tinker with now so perhaps I will get rid of the 16v unit and find a 8v I can rebuild.
Offline Sam
  • Sam I am
« Reply #4 on: 06 December 2010, 12:01 »
If your talking about purely the 'cylinder block' i don't think you can. Pretty sure the 16v has oil jets or such like and the 8v don't. Don't quote me on this as i cant find any info on it.
« Reply #5 on: 06 December 2010, 12:05 »
Yep 16v has piston cooling jets
Offline juicey
« Reply #6 on: 06 December 2010, 12:08 »
Thanks guys, yes you are correct the 16v block has oil jets so will have to find a old 8v lump to play with.
« Reply #7 on: 06 December 2010, 14:33 »
the basic block is pretty much the same, as well as the cooling jets it also has a breather on the front. you'll need to change the pistons, intermediate shaft, oil pump and both timing belt sprockets
Offline Sam
  • Sam I am
« Reply #8 on: 06 December 2010, 14:49 »
This is pretty much the impression I get from near enough every post you make johnny
