Author Topic: home made wheel bearing press  (Read 7333 times)
Offline Cory
« on: 03 December 2010, 01:36 »
i remember seeing a post where someone had made their own jig for pressing in wheel bearings out of some pretti basic stuff.
anyone know who that might have been?
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: home made wheel bearing press
« Reply #1 on: 03 December 2010, 16:36 »
ive used a porta power in between a door frame which is what they use for car body work. I don't recommend using a vice as i broke mine in half.
Offline Cory
« Reply #2 on: 03 December 2010, 17:26 »
ahhh.  i just remember seeing someone using a DIY device.  it was soo simple and i remember thinking it would be really effective.    it was basically b piece of wood to clamp the bearing housing to, and a threaded rod with a socket behind a tapped breaker bar kind of thing. set up on a workbench
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 03 December 2010, 17:27 »
a garage will charge you only a few quid to 'just' press the bearing..
Offline richard s
« Reply #4 on: 03 December 2010, 20:47 »
a mechanic i used to work with used to use a piece of threaded bar with a nut welded on one end with a piece of flat bar drilled for a stop then sockets and various bearing shells till the company stopped being tight and bought him a press
« Reply #5 on: 03 December 2010, 23:58 »
Yep much safer
Offline Ben Lessani
« Reply #6 on: 04 December 2010, 00:37 »
Don't bother, you'll most likely f**k up the bearing.
You can buy/rent a press cheap, or as above, just get a garage to do it for buttons.
When you've seen a bearing 'ping' out of the WBH - you'll be less inclined to bodge!
There's two things I don't like messing with when working on cars, assembly/disassembly of springs+struts and pressing things!
Offline beechymonza
  • mad beech
« Reply #7 on: 04 December 2010, 10:43 »
I remember using a piece of scaffolding pipe on my rear ones,  Worked a treat,  :cool:
No guts No glory,
Offline Ben Lessani
« Reply #8 on: 04 December 2010, 11:43 »
Ah, rears are different, you don't need a press. You can tap out the races with a small hammer and stake.
Offline Mr Blue
« Reply #9 on: 04 December 2010, 12:07 »
Just dont take a hammer to the bearing without personal protective equipment.  :embarassed:
