Author Topic: Blocked heater matrix  (Read 4165 times)
Re: Blocked heater matrix
« Reply #10 on: 12 January 2011, 09:57 »
yeah thats the oily coating on the matrix burning off, you need to clean the matrix thoroughly before you fit to remove it. it will burn off though, eventually  :grin:
Offline rob.043
« Reply #11 on: 12 January 2011, 10:48 »
Have you driven far with the new matrix fitted and definately got all the air out? It took a bit of squeesing of pipes and driving of miles to get mine fully bled. But if you have a new matrix and no bypass valves, you should have a hot car pretty soon!
Offline TreadGingerly
« Reply #12 on: 28 January 2011, 13:39 »
It's on ebay !! Going to put the money into my T25. Traitor!!  :grin:
Offline mr mk2
« Reply #13 on: 28 January 2011, 14:13 »
i had a simmilar problem and it was 1 of the 3 way adapters that fit onto the heater pipes under the bonnet had blocked so after a quick trip to the scrappy hay presto all sorted
« Reply #14 on: 28 January 2011, 16:17 »
 :rolleyes: I am sure it would sort itself out in the end.
Offline Mr Blue
« Reply #15 on: 28 January 2011, 20:40 »
this problem has come up again.
colling system has no leaks.
when giving it some on the motorway it gets warm. once slow it gets colder?
waterpump is new, thermostat new, engine temp never goes past the middle.
hope its not the matrix
« Reply #16 on: 28 January 2011, 23:28 »
Try another / genuine thermostat 1st
gixer1400
« Reply #17 on: 29 January 2011, 23:46 »
have you checked that the heater flaps are in good condition ?
if not the heat level will be miserly and for some reason the temperature gauge will show a low level or not
move at all  :shocked:
take out the center vents; very easy to do ; shine a torch down the vents and move the control lever to
see if the foam on the flaps has perished  :huh:
if so you need to sort them out ; see any of the guides to help you  ; its worth the time spent  :cool:
Offline Reasty
  • Alpine white valver.
« Reply #18 on: 30 January 2011, 18:48 »
I had a similar problem today,got the car out after 6 months in the garage and had no heat from the heaters at all,i put a new matrix in before she went away for winter so i knew that was fine,i solved the issue by disconecting the return pipe from the valve as it was not hot at all,firstly alot of cold water came out then there was a surge of slush and water then the water was so bloody hot it scolded my thumb so i did have a blockage in the matrix,i wouldnt advise what i did as it hurt ALOT but now its well toasty again  :grin:
