Author Topic: Blocked heater matrix  (Read 4147 times)
Offline TreadGingerly
« on: 02 December 2010, 22:24 »
No heat again... well a bit of warm air that's as helpful as lighting a match in this weather.. Will water pass through the matrix if is sludged up? Had other issues during the summer, flushed the whole system including running water directly through the matrix. The pipes to and from it feel hot. The bypass valves have been done away with... Any ideas, I'm freezing !!
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Blocked heater matrix
« Reply #1 on: 03 December 2010, 00:56 »
Have you bled it properly?
Have you checked its got antifreeze and its not frozen up??
For More Info Click To See;
« Reply #2 on: 03 December 2010, 08:44 »
if blocked it can still pass a bit of water thru it, as there are loads of channels in parralallelell
« Reply #3 on: 03 December 2010, 11:22 »
Yep, bled, antifreeze, double checked... Looks like replace the matrix time :-(
Offline delirical
  • Like a g60
« Reply #4 on: 03 December 2010, 13:33 »
My heater is working but not through the main heaters i.e. passenger 2xcentral and drivers side.. it works for the feet and windscreen thank god! any ideas?
Offline tony_ack
« Reply #5 on: 03 December 2010, 21:27 »
Likely to be a snapped cable between the heater controls and heater box. You can get replacements from VW (or at least you could 12 months ago)
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
« Reply #6 on: 21 December 2010, 23:05 »
I did this job this afternoon... what b*****d. It's a bit warmer but still not like toast. Anyone want to buy a G reg Golf ?
« Reply #7 on: 22 December 2010, 08:38 »
check the cooling system over as per the coolant guide in the maintenance section, in particular mkae sure the stat is fully shut when cold and that water comes out of the thin header tank hose when you rev it. though you might just find the matrix has a stubborn air lock, sometimes its taken a good motorway thrash to clear all the air out of the matrix on mine.
did you check all the flaps inside the airbox were intact while you were doing the job? if the foam falls off the warm air flap it wont fully shut and cold air can bypass the matrix
Offline sparks03
  • Look at the veins in that
« Reply #8 on: 22 December 2010, 11:23 »
http://shop.ebay.co.uk/?_from=R40&_trksid=p5197.m570.l1313&_nkw=vw+golf+mk2+heater+matrix&_sacat=See-All-Categories
 I've been thinking of replacing the matrix since the exploding thread. Seems like there's plenty out there, will be an after Christmas job now.
<br />   Heaven is 13 feet long
« Reply #9 on: 11 January 2011, 23:20 »
Ever since doing this job the inside of the car stinks... I thought I'd give it a bit of time to settle down... Film of something on the windscreen initially, that's stopped now.. But this smell...not nice, any ideas? Foam is still intact and seems to be making a seal where pipes pass through bulkhead.. I did use the cheaper matrix available from German and Swedish.
Oh...and it does get warm(ish) !
